ABS Clearing Code Instructions+(Help)
CLEARING OF MALFUNCTION CODE (ABS+Other codes too)
(a) Connect service wires to terminals Tc and AB of the check connector.
(b) Turn the ignition switch ACC or ON and wait approx. 6 seconds.
(c) Starting with the Tc terminal, apply body ground alternately to terminal Tc and terminal AB twice each in cycles of 1.0 ± 0.5 seconds. Finally, keep applying body ground to terminal Tc.
HINT: When alternating between body ground of terminals Tc and AB release one from body ground while applying it to the other terminal. The time interval in between must be within the following conditions. If it is out of the conditions, code 41 will not be cleared.
Can someone help me translate this sentence?
Apply body ground alternately to terminal Tc and terminal AB twice each in cycles of 1.0 ± 0.5 seconds.
Thank You
Thank You
So you're saying, if your ABS light is on, and you perform this task, the light will go off?
I'm just clueless when I see these AutoCAD drawings and dunno wat to do
My ABS light came on recently and that light is getting ANNOYING along with the blinking needles....
Yes Reset your ABS light
Re: ABS Clearing Code Instructions+(Help)
Thank You
Thank You
Hint: Use two small paper clips and stick in the Tc and AB. Then use those clamp clip on one end and a sharp point tip on the other end, of course there is wire between those things. You can buy these from Radio Shark or they cam as accessories for some of the engine check equipment. Now alternately touching the car metal within .5 to 1 sec. If the ABS light did not goes out, you need to do it again.
Good Luck
Thank You
Thank You
My Airbag light is on also will this clear that too?
