SC- 1st Gen (1992-2000)
Video of 1JZ breakin up
Old 06-15-11, 02:34 PM
nnivlemm
nnivlemm's Avatar
Default Video of 1JZ breakin up
My 1jz swapped SC is breaking up as you rev it through the RPMs, and I don't know why. It's not the coil packs, or the MAP sensor, spark plugs are gapped properly, so I was wondering if anyone had found similar issues and fixed them.http://http://www.youtube.com/watch?v=uxk0WodV5mg
Old 06-15-11, 02:41 PM
mr/griffin
mr/griffin's Avatar
hareness, sounds like weak bad ground or short something. maybe fuel filter. weak pump kinked line maybe
what fuel you running
Old 06-15-11, 02:42 PM
scviolence
scviolence's Avatar
what are your plugs gapped to and are you running any kind of piggy back ecus? any check engine lights?
Old 06-15-11, 04:38 PM
meangreen1
meangreen1's Avatar
Check your fuel system. Whats your fuel psi when reving?
Old 06-15-11, 07:55 PM
6SOARER
6SOARER's Avatar
Sorry to hijack this but since everyone is talking fuel system, How would one run a fuel pressure test on a 1JZ?
I borrowed a Master Fuel Tester kit and theres no way I can get the fitting on the Fuel Banjo bolt that lies at the end of the fuel rail. The adapter will fit but the fitting from the testers line hits the firewall.
Is there any way to test fuel pressure by the fuel rail?
Old 06-15-11, 10:03 PM
meangreen1
meangreen1's Avatar
Make a "T" in the rubber hose and put a gauge in there. Simple test to elem. this theroy.
Old 06-15-11, 10:45 PM
6SOARER
6SOARER's Avatar
Before when the GE was in there was no problem with fuel pressure, after I dropped in 1JZ the problem began. I wanted to put the gauge after the fuel dampner but the lines are steel. .
Im assuming pressure is good from the tank up to the dampner. Im questioning the line from the dampner to the fuel rail. I had a custom line made cause the stock link was all kinked and I initially thought that that was my problem.
Old 06-16-11, 05:18 AM
RyanV
RyanV's Avatar
Maybe look inside the ecu for damage.
Coil pack wiring
1JZ/240sx
Build Threads
09-10-16 03:56 PM
Biggu
SC400 / 300 Classifieds
12
01-29-12 06:15 AM
6SOARER
Performance & Maintenance
06-24-11 08:45 PM
1JZSc300
12-14-10 12:28 AM
Quick Reply: Video of 1JZ breakin up
