Hey 1JZ guys what kinda power you putting down?
#106
I'm speaking from experience. My last car was nearly 500whp on a Walbro, 5spd, 550cc injectors, 3" exhaust and a mapecu2. That's it. No fpr. Now if you want one it's not a bad idea, I'm not Sayin it wouldn't be a good thing. But since your on a budget, it's a expense that's unneeded. (plus you'll need new fuel lines or atleast adapters that will let you install -an line fittings to your stockers)
For the wiring I believe it was harness to safc to bcc to ecu.
This thread confirms that:
http://www.supraforums.com/forum/arc.../t-407618.html
#107
I made 522RWHP, 421 torque with a BW S366. Mods are the following:
AEM V2 standalone
800CC injectors high impedance
-6 steel braided fuel line feed, stock return
MINZ fpr
Greddy electronic boost controller
HKS BOV
Tial 44mm wastegate
T4 DM manifold
DM dp
-3 oil feed line to turbo
BC 264 stage 2 cams
TT fuel pump
this is on 93 octane too....
AEM V2 standalone
MINZ fpr
HKS BOV
Tial 44mm wastegate
T4 DM manifold
DM dp
BC 264 stage 2 cams
TT fuel pump
#108
So right now I got
1jzgte soar
Safc2
550cc supra injectors
2 Walbro fuel pumps
Gt3582r eBay knock off
410hp on 93 and 510 on 112
BC 264 cams next week still do no what to shot for with 93 octane yet I heard 93 and 410hp is max. I see you guys making 500+ on 93 with close to
My setup. Any idea of what will be safe with my set up + 264 BC cams on 93?
1jzgte soar
Safc2
2 Walbro fuel pumps
#109
1JZ Single SC400
With cams and a retune, I would say to say 450-475. This depends on timing and type of gas, and how much boost the tuner feels safe before detonation. I think your turbo and injectors are your limits to get into the 500 mark. I am not saying it can be done, but I base my predictions on what you stated and what my car made. All in all, the tune is the most important.
#110
So right now I got
1jzgte soar
Safc2
2 Walbro fuel pumps
1jzgte soar
Safc2
2 Walbro fuel pumps
#111
1JZ Single SC400
Even if you do make the 500 HP range, when is it ever enough? I was shooting for 500 plus, and I achieved it, but barely. Do I have room to grow, yeah. The limits are injectors and pump. I have one of those ready to drop in. But then a retune, and will it ever stop??????? I think the cams helped me, but how much I don't know. I added them before the car even ran. On average 35-50 hp. I think anything over 600 you will have traction issues, just ask Jay... He knows.. His would blow the tires off in any gear when in boost hard.
#112
Cool thread guys. I will be using this once i get my motor for ideas on achieving my power goal. But like 1jzPWRD said "there is no suck thing as enough" haha which is so true. I learned that when I boosted my IS and only wanted 300 and when said and done i ended up around 400hp.
#113
Enough ..yeah sure when you need $7k to go from 500 -750/800whp and you max your 500hp setup and you don't have that $7k you will stop, that 500hp will be enough for you.
700 my car dead hooks in first gear all the way, every time !! Get some real tires and the suspension dialed in and you won't have traction issues.
Combination, combination and combination get it right and you will make some power without even trying!
