Exterior Wrapping Q
Exterior Wrapping Q
Planning to wrap my car with matte black, seeing it is the cheaper option than painting. If wrapping is done with 3m, is it easy to remove or it be a pain? and is it possible to paint over the wrapped?
Well, for matte black you have a few options. Of course there is the spray can method
which is the cheapest. Then you can buy a roll of 3M vinyl wrap material for around $500 dollars. It all depends on how much you care about the exterior of your car. Obviously
with the vinyl method, you can remove it later on. Spray can will probably take a few
hours vs vinyl which will take an ametuer about two full days and it will help to have a
second set of hands. Matte vinyl wraps look much better IMO but then again I'm biased
since I'm in the vinyl industry.
It is very easy and cheap to paint your car with a matte black----just buy a base coat of whatever color you like--------rent or buy a small hvac compressor----not expensive---and paint away----------of course because it is matte-----it hides alot of imperfections in your body
