SC- 1st Gen (1992-2000)
DIY: Releasing valet feature when you do not have master key
Old 08-18-10, 04:30 PM
saurah
saurah's Avatar
Default DIY: Releasing valet feature when you do not have master key
I ran into a problem where the valet feature got turned on(pushed in). Unfortunately, my one and only key does not open the trunk, or unlock the valet feature. So I had no way into my trunk. I'm not sure if this is common knowledge or not, but if someone could have told me this it would have been nice!
You need to remove the entire panel to access the back of the lock.
(https://www.clublexus.com/forums/sc-...-56k-nono.html)
Once you've done this, you should see a copper looking clip surrounding the base of the lock. Simply pull this off with your fingers, or pry with a small screwdriver.
When this is removed, take a small screwdriver and press the small black button (now exposed) in, and towards the left. It will pop back down, and the lock will be out of "valet" mode.
SUPER easy fix. Reinstall the clip, and panel and your good to go.
Attached Thumbnails DIY: Releasing valet feature when you do not have master key-lock-1.jpg   DIY: Releasing valet feature when you do not have master key-lock-2.jpg
Old 08-18-10, 04:47 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Nice DIY! How did you figure this out?
Old 08-18-10, 06:54 PM
chnk
chnk's Avatar
will this fix the trunk not being open with the button inside? how do you turn the valet feature on?
Old 08-18-10, 10:18 PM
saurah
saurah's Avatar
I actually read it on here on a thread from like 2002. I couldn't understand what he was really talking about, but after digging around I got it.
Yes, if the valet feature is on. To turn it on, all you do is push the lock in. If its pushed in, and you cannot unlock it with your key this will be the trick to fixing it.
Old 09-12-12, 06:27 AM
paco15506
paco15506's Avatar
man this thread really was helpful finally open my trunk after locking up on the second day i got it wish was 2 years ago lol
Old 09-12-12, 07:52 AM
Taken
Taken's Avatar
Your signature just made my day, LOL.
xMUZZx
09-19-21 12:23 PM
Chione
14
04-20-20 04:46 PM
GeorgeG5
07-17-17 01:02 PM
vipman806
GS - 1st Gen (1993-1997)
08-08-12 11:22 PM
MyR6eatsme
09-05-10 01:46 AM
Quick Reply: DIY: Releasing valet feature when you do not have master key
