SC- 1st Gen (1992-2000)
1992 Lexus SC400 Taillight ???
Old 04-30-09, 03:58 PM
dirkdiggle
dirkdiggle's Avatar
Default 1992 Lexus SC400 Taillight ???
I know I am beating a dead horse here but I am going to ask......searched "taillight fitment"......returned nothing but I am sure this has been covered!
Will 1995 Sc400 taillights work on a 1992 sc400 without modifications?
Old 04-30-09, 04:06 PM
Amini9
Amini9's Avatar
you need the harness. if you put any newer taillights on the 92-94 SCs, it will have hyper blink.
this is the fix - https://www.clublexus.com/forums/sc-...aillights.html
i think you might also have the tail light 'is out' sign on in ur car, but that part im not sure about.
Old 04-30-09, 05:14 PM
SHOLEXMAN
SHOLEXMAN's Avatar
Check out that link should help you out. No you you need to mod your harness same thing with the 97 and up tailights.
Old 04-30-09, 05:25 PM
schwarz
schwarz's Avatar
Like the others said, you also need the 95-96 harnesses. The taillight out warning light on the cluster works just like it does with the 92-94 tail lights (it only goes on when a bulb is out).
To fix the hyper blink with the 95-96 taillights, you'll also need the flasher relay from the same year.
Old 04-30-09, 05:30 PM
KrazeMatik
KrazeMatik's Avatar
yes it i will here my link https://www.clublexus.com/forums/sc-...il-lights.html
Old 04-30-09, 05:36 PM
durtysc300
durtysc300's Avatar
so if i put 1997+ lights on my 1995 i'll have to get a relay and the harness too?
Old 04-30-09, 06:17 PM
schwarz
schwarz's Avatar
97+ tails on a 95-96 will also need the 97+ harnesses. Basically, whatever tails you decide to put on, you'll also need the corresponding harnesses.
Old 04-30-09, 06:24 PM
Amini9
Amini9's Avatar
harness yes, relay no
Old 05-14-09, 12:15 PM
95silversc
95silversc's Avatar
I have almost the reverse question as the OP. I have a 95 SC and I put 92 tails on it. The blink seems normal but its triggering the taillight out lamp on the dash how do I fix this?
Old 05-14-09, 04:15 PM
6SOARER
6SOARER's Avatar
I have 97 tailights with harness on my 92 but I'm getting the hyper flash and rear brake out indicator on my cluster, so will I have to get a 97 relay or mod the Capacitator on the relay itself?
Old 05-14-09, 04:20 PM
Amini9
Amini9's Avatar
umm.i think both would work. im not sure about the rear brake out indicator, but the hyperblink is fixed by that capacitor.
Old 05-14-09, 07:29 PM
One_jZ_SC3
One_jZ_SC3's Avatar
The horse is now been laid to rest and hoofs used for glue!!!
1320VR4
SC400 / 300 Classifieds
01-10-14 07:44 PM
golfer0059
05-08-12 09:21 PM
Brian231
20
08-15-08 06:54 PM
SteveTPA
11-10-07 03:06 PM
PlatSilvSc
12-21-06 11:53 AM
Quick Reply: 1992 Lexus SC400 Taillight ???
