Sc300 Fog Light
Sc300 Fog Light
I own a '92 SC300 and would like to install a set of fog light. I found PIAA 1400 & 2100 Series and Hella Micro DE Halogen but can't find a spot to install it. Pls. help. Would it be possible to install fog light without modification? If so, what is the preferred brand/model? My thanks in advance.
Not sure if this is the type of answer you're looking for but after market foglights dont look really all that attractive on the SC's. If you must install one, then it can be done being bolted/screwed directly into the aluminum bumper support and would peak through the bottom grill area. You might have to open up the grill for clearance so the light can peak through. IMO look into possibly upgrading to the 97+ front end if at all possible.
Kruso
Kruso
My original plan was to use a Hella Micro DE Halogen Lamp but it will take a while before I can get it so I cancelled my order. I decided to buy a Rally fog light instead. I am sorry I should have saved those boxes so I can provide you with the Model#. I bought a remote controlled switch made by the same co. and wired it. This set-up is just temporary while I am doing my research on which lamp(s) to use.
This one is available at TMTuning but I am still waiting for their response.
http://www.tmtuning.com/vw/
I prefer the blue ring......
