Removing Exterior Door Handle/Keylock
i just had my door apart to fix my regulator, and i thought about removing the handle to get easier access. it looks difficult because the window rail is in the way.
you need to remove the lower torx screw on the window rail and kind bend it out of the way to get a socket in there. i am not positive this will work but the rail is definately in the way and you can move it to a certain degree with the screw removed. or get one of those flexible ratchet deals. good luck
Looks like I will be doing without!!
Jonny
