Just bought 97 sc300 bumper and sideskirt!!!
97+ sideskirts
Hello guys. I know most of you do not play with sc300 any more, but I just got a 94, sc300. I have looked and read how to many times to put the side skirts on. I just cant fit it on place. I took the stock moldings off. But the pair of used side skirts I bought, does not quiet fit perfect. I am seeking advice from you pro's please help me out. Does the skirts needs to be modified? I removed all together 6 pieces, 3 from each side. And please don't replay me with the picture from Sewell Lexus. I have tried to get an understanding but didn't work out. Thank you in advance for your time.
Just picked up some side skirts from extreme dimension. For a great deal being that I am sponsored. If you find the thread let me know looking to install today. Congrats on your purchase!
Thanks you guys
Hey guys thanks a lot for feed backs. Been really busy with school. Sorry for late replays. I will check them pictures Asha'man......also how did your skirt installation go? at DcW58....post some pic if possible. Thanks.
side skirts are extremely easy to install. first unscrew the wheel well trim and open up the wheel well plastic and you'll see a small 10mm plastic bolt that hold the trim pieces, that bolt will break and underneath it will be an 8mm bolt, unscrew that or break it off depending on rust levels, and then just slowly take the trim piece off. the same goes for both front and back. once you have those off, open the door and unscrew 2 screws holding the black trim piece, keep the screws because you'll attach the sideskirts with those. that's basically it, just slap the skirts on with their clips and they'll fit perfectly right in. now the wheel well trim pieces will either have to be trimmed or cut, or you can drill holes in the side skirts and screw the trim pieces on top and through the side skirts, up to you. it's really simple, i've never done it and it only took me about 15 minutes. Once you hold the side skirts up to where they're supposed to go, it will make sense. PM me if you have any more questions.
jgdynamics
SC400 / 300 Classifieds
01-04-13 12:36 PM
313sc3
SC- 1st Gen (1992-2000)
17
07-02-12 08:25 PM
