08-14-05, 05:17 PM
Drinkin' the Kool-Aid
My Easy, SImple, Not Hard Guide to Painting Your B-Pillars
I don't know about you guys, but after a while I noticed my passenger side B-Pillar on my SC300 started to crack and peel off leaving me with a big silver spot that kept growing as more paint chipped off. One member decided to just take all the paint off on both sides leaving it all silver, but that just didn't look right to me. I like it the way Lexus made it to be -- all black. In fact, not just black, but black metallic. Whether you notice them or not, those metallic pieces REALLY make that B-Pillar. In fact, the paint that was used is such a close match to the original paint you can't even tell that we painted it. It's THAT close. So here we go, on to my easy guide to painting your B-Pillars. The job was done by my girlfriend's dad and I this past Thursday. I forgot my camera so I had to use hers to take pictures, then I forgot to take it with me when I left that night so I had to wait until yesterday to get the pictures. Ready? Here we go!
Note: Keep in mind this process will probably work with other Lexus models as well, but I happen to have an SC and I know it definitely affects SC owners. Plus, I wasn't sure so I just assumed this would be the best spot for my tutorial.
What we used: - Tape
- Sand Paper (220 and 400)
- 2HP Air Compressor
- 2 Paint Spray Guns
- Newspaper (B&W or color both work OK)
- Epoxy Primer
- Activator and Hardener (to use in paint)
- Omni Medium Reducer
- Silicon Drops
- A Few Rags
- Tack Cloth (to remove dust)
- Lots of Time
Here are the before pictures, the first two of the worst side and the third of the driver's side, not so bad (but we did both to be consistent)
If yours is like mine, start by taping the edges of the pillar around where you will be sanding to avoid damage to the window or other areas.
Now go ahead and sand down the areas until you've successfully feathered the areas down to blend them together. You don't need to take ALL the paint away, just enough to ensure that the paint will go on smoothly. Start with 220 (or equivalent) sand paper and a block to wrap it around (if you have one) to do the feathering. Also, make sure you sand paper the rest of the B-pillar to ensure proper paint bonding. The driver's side was also sanded down to make the paint bond better. You can also move to a 400 sand paper if you want, and wet it down to maintain long life with your paper.
__________________
Ben :: 1993 SC3 :: 5 Gears :: 100% Delicious
CEO - Team Late Night, Inc. # 2.5
08-14-05, 05:18 PM
__________________
08-14-05, 05:19 PM
__________________
08-14-05, 05:21 PM
Now I didn't want to split it into multiple posts, but I got yelled at when I tried to post too many IMG tags in one post.  Also, can one of you mods decapitalize my I in simple? It's a small detail but that sorta thing bugs me.
__________________
08-14-05, 05:35 PM
Looks great!  At least I'll know what to do if mine ever does that, but of course I'll need a paint gun.
08-14-05, 06:08 PM
nice writeup!
__________________
- starting up again soon -
08-14-05, 07:30 PM
Dope DIY  You're in the club. Check your PM.
__________________
08-14-05, 07:40 PM
Excellent!
Now to procure a paint gun.
Nice use of the vice
What did you use the air compressor for? You listed it in the items, but never mentioned it in the DIY?
__________________
1994 Lexus SC300 AT - $#%&ing WRECKED
BMW E36 - 1999 328iS 5-speed +Black/Black
http://www.clublexus.com/gallery/dat...36erbright.jpg
|Smoked Corners w/ Stealth Chrome Yellow Bulbs|Smoked Fogs with 3000K HIDs|Smoked Sidemarkers|6500K XenonDepot HIDs||Black Kidneys|Wood Grain Delete|Smoked Red/Clear Tail Lamps coming soon...
T.L.N. #11 RETURNS
08-14-05, 08:22 PM
Quote:
the air compressor was used for a few things, including both paint guns and also to spray air over the areas to ensure they were clean.
Quote:
great minds think alike don't they?
__________________
08-14-05, 08:22 PM
08-15-05, 09:11 AM
Great writeup!!! I need to do my wiper arms as well, and this is definately a better way to go than a spray can!!
__________________
sig created by GSoup
"I am a carton of Hate and he is a wedge of Spite."
TLN member #17 (and you don't want to know why)
08-15-05, 12:05 PM
Elite! I would do this if I had the time. Is the B-pillar body colored stock? I don't think I've seen mine with paint on it ever...
__________________
-Allen Mok
10-11-09, 09:38 PM
All the picture links are down.
10-11-09, 09:54 PM
1999 Lexus SC
Cause this thread is 4 years old.....
__________________
under construction. tee hee.
10-11-09, 11:43 PM
I found it from the sticky DIY section, so I figured whoever maintained this would want to know.
Thx
| Thread Tools |
| Display Modes |
Hybrid Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
