help finding matching fcc id key
What year is your car?
If it's a 92-95 then you're just going to have to buy a new pair of keys + a chip from the dealer if you want the keyless entry to work again. The keys and chips are programmed from the factory and can't be reprogrammed.
96-97: I've never had to work with this keyless entry system, so I have no idea.
98-00 you might get lucky on ebay, but it would be easier just to buy a key from the dealer or a local lock smith.
You'd need the keys, all the key cylinders, and the chip for it to work. Chances are the keyless entry stopped working on another 92-95 model since its a common problem.
If you were to buy it from the dealer, then you get 2 blank keys that they'll cut to match your car, and a new chip for you to install that will match your keys.
beachlover
RX - 1st Gen (1999-2003)
12-04-13 02:36 PM
saj070
07-22-10 02:15 PM
