Factory radio Tape deck inop
Bought one of those cheap cassette to aux things to hold me over till I get a new radio. But when I press tape or cd it does nothing. Could it be because the cd changer is gone? Or is it just trash lol
Yes, once you delete any part of the system it wil not play, unless you find a diagram of the audio system and bridge the wires. You can install the cd changer if you have it should be plug and play even if the cd changer doesn't work, but it's hooked up your tape deck will still play through speakers
Otherwise you have to delete the amp and your whole system and start fresh all new (deck, amp, sub and wiring etc)
You can still use the stock amp, but you may lose sub amplification. It's not exactly plug&play, no. The Metra Kit will usually get you installed with the 4 channels, but it'll be real tinny, no bass. There are quite a few threads about replacing the deck and what all is involved.
It does matter what you have now, being Nakamichi or Pioneer (there's basically 2 Pioneer systems, but you had the CD Changer, so you should have the 10", 1 ohm sub.)
Aron9000
11-26-13 12:48 PM
Lexscme
09-24-09 02:02 PM
lexusaudio
06-29-03 08:47 AM
