SC400 100KPH with 2 loose bolts holding the Half axle in - inc video
SC400 with 2 bolts holding the Half axle in - inc video
I run an SC400 uzz30 1UZ-FE
What I'm not sure about is
Why did the bolts come out
Should I clean all the grease off, and locktite the bolts in. I just put replacement ones in without removing the grease.
Re-pack the CV joint and how do you do that without opening the rubber boot up.
What hose got cut
What is the reason for the 3 bolt "washer"
Anyone know what the bolt tension should be?
Is the half axle got a CV joint at one end or does it go by a different name.
Story:
I reckon I was so lucky with this not turning in to a mess.
I had an interesting ride home the other day. I had just come off the freeway sitting on 100KPH (60MPH) without any signs of the pending problem with my car.
I have an in car camera so fortunately I caught the failure on video, or at least the noise it made and consequently the noise it made when it seemed to sort of fix itself e.g. perhaps the CV joint (I'm guessing that's what it is called" popped itself all the way back in.
I later found I was missing 3-4 bolts and the last two where out buy 12mm (1/2") out and green grease from the joint was all over the exhaust and under body area.
I found the clicking sound was caused by a "3 bolt washer?" that had only one bolt holding it in which allowed it to swing out and hack at what I think is the return fuel breather line. Perhaps someone could clarify that for me.
I show that in the video.
Here's the link to the video.
I was very lucky to get replacement bolts as it was closing time and the next day was a public holiday.
Half axle bolts missing
Sorry about the long post.
What hose got cut
Story:
Last edited by lateralnw; 11-07-15 at 06:16 AM. Reason: Clarify heading, point formed the beginning, reduced text.
I did source a new "washer" I asked my engineer brother in law - he didn't seem to know why they are used but i have replaced them. He thought they had the bent up metal plate which in other situations would stop the bolt from undoing... he is a ford engineer so that might answer why he didn't know...
I added this photo for others, to clarify what we are talking about.
In case its not clear in my case it is a three bolt "washer" - don't really know what its called or why its there but I put it back just cause!
Your right No it shouldn't look like that. It is broken and the reason is it has been spinning at god knows how many rpm while cutting through what I think is the return breather line for the fuel tank and only then I reduced speed did it seem to make itself know as a problem.
In the video you can hear the "washer" (I don't don't know that it really should be called) banging on the return breather hose of the fuel tank. It eventually cut the breather line and also I am guessing breaks in to half a circle "washer"
It seems it has been posted before this issue but I didn't what to bump such an old thread.
ref: https://www.clublexus.com/forums/sc-...-pics-fix.html
thanks for the supporting comment.
All the best with your many builds.
Hi thanks for the feedback, much appreciated.
I have since checked the bolts and they all seem to be in tight.
2IS350DT
03-11-11 02:32 PM
assass1n
Suspension and Brakes
14
02-08-09 03:53 PM
