Off-Center Steering Wheel
I did. They have poly bushings that I installed not 2 months ago.
Just had someone else turn while I looked. It's moving quite a bit. :\ I think it's the clamp-shaped bushing that's too loose. I can't imagine how the other two would allow for any lateral motion, even if they were loose.
~60 ft/lbs for each, right?
yeah mine was the same way I have noticed it after changing out those bushings. the c clip one does not seem to be nearly as good as the oem one and allows for movement. I thought the small ones that get bolted down would still hold the rack in place like you are thinking also, but being poly I now think the movement we are seeing is the give in those poly bushings. I am ordering aluminum after watching your video it only confirmed what I suspected.
UPDATE:
I went under today, and for some reason...the three bolts were only tightened to around 20 ft-lbs. Factory spec is ~60.
By Ali's recommendation against the poly clamp bushing, I replaced it with the OEM rubber one, and then re-torqued everything to spec, and.....voila. No more rack movement.
Except now I need another front alignment because my last one was with the loose bolts
I can't believe I missed that- I could've sworn I torqued them to spec. Either way, they are now!
ls400love
Suspension and Brakes
12-29-14 04:01 PM
