Front wheel fitment
Front wheel fitment
Hi all, I'm planning out my Christmas list of goodies and recently saw the Varrstoen thread. After looking up and playing with the sizes and offsets I found the wheels I think I want to get. but before I commit I wanted to check and see if a crazy idea I had might work:
I want to try a super wide square fitment wheel setup:
11 inch wide 35 offset with 305 section tires. I figure the rear will work. My question is do you think the front will clear on the inside? If not, what would I be contacting (rubbing on full lock, hitting the control arms, hitting the shock body?) Those who have experience with super wide front wheels with a lot of back spacing please chime in.
and yes I did do some searching but came up with very little information.
Biggest you can run on the front would be a 10 in wheel....and largest tire would be a 285.....
Look up CCW Supra fitment......most run 18x10 with a 285 and 18x11.5 with a 315
Offset is the most important part for running a square setup....the CCW wheels are in the +40-50 offset range.....
IMO.....a 10" wide rim is plenty in back with the right offset you could run a 295 tire on it...offset would need to be minumum +35....
with a 18x10 +25 offset you can run a 275 tire with fenders rolled completely flat...
^ take his fitment with a grain of salt as his fenders are pulled a good amount and you'd have to do similarly to get that big of a wheel under there (love the look tho obeewon, but miss the red equips on your car )
That is the closest part, I run a bit less caster than stock so I have absolutely no rubbing. I plan on going up a tire size once my fronts are done. I probably have about 20mm of pull on these fenders.
