SC- 1st Gen (1992-2000)
sc400 tach problems
Old 09-26-13, 09:29 AM
jmanhas
jmanhas's Avatar
Default sc400 tach problems
I have a 1jz sc400 swap and my tach lights up but wont move anyone have any idea what this is and ways to diagnose? I know might be motor but could there also be a sensor not hooked up ect
thanks
Old 09-26-13, 10:34 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Could be the needle set to far down on the motor, or the sensor from tranny not hooked up, or you dont have the resistor on the back of the motherboard not spliced together. The number you need to have jumped is R73 or R109. Pull the cluster out and remove the back white plastic piece and see if there is a wire that is indeed ran across either of the resistor I stated. The number is based on which cluster you have. Keep in kind the 400 cluster will be off like 1000-1500 rpm faster than what is should be. Worst case post a picture of the cluster.
Old 09-29-13, 07:51 PM
jmanhas
jmanhas's Avatar
the mb
the connection
no connection?
my needle rest very low
Old 09-30-13, 12:08 AM
jmanhas
jmanhas's Avatar
any ideas?
Old 10-01-13, 12:34 AM
jmanhas
jmanhas's Avatar
pwrd or anyone offer help lol
Old 10-01-13, 03:45 AM
SC4ME
SC4ME's Avatar
thanks
my clusters main needle just stopped working and my o/d off light started blinking, i pressed the o/d but nothing happened, lexus told me my speed sensor stopped working (code 42). but now heres the real problem: theres 4 sensors in the sc4 (which btw mine is a 92 1uz). 2 speed solenoids and 2 sensors. their all attached to the tranny on the sides. but im not sure if thats the case in your situation, im hoping it helps
Old 10-01-13, 11:58 PM
jmanhas
jmanhas's Avatar
do yu know where the rpm sensor is lol nd is the needle supposed to rest below zero
skoles
Performance & Maintenance
10-08-17 07:08 AM
Harsh2000
07-27-17 01:43 PM
scott8851
08-06-12 06:05 PM
rc0
SC400 / 300 Classifieds
05-21-05 08:59 AM
Quick Reply: sc400 tach problems
