SC300 Sunroof wont close
Hi guys
Been a few years since I have been on this forum since owning my GS300, well got a SC300 into the family now running a 1JZ
Now recently got a bit of a problem, the cars new to me still and went to open the sunroof and it opened fine but now it wont close.. so im stuck and I need the car asap as its a daily driver.
I looked at the owners manual and it says that you can remove this one screw to be able to manually open and close the sunroof and after doing that nothing happened at all.. its just as hard to close as normal.
Anyone able to give any advice on how to fix this? I dont really mind never using the sunroof again so I would just like to close it for now and think about fixing it another day.
Thanks guys
Thanks guys
Check THIS thread.
I saw domelight fuse and accessory fuse mentioned in that thread. I just searched "sunroof won't close". You can try "sunroof stuck open" also.
(just in case, when you are in the Sc300/400 forum, don't use the white search box in the center, use the one on the right that says "search this forum" so you don't get Gs, Ls, Is answers)
Did you check all your fuses?
Good Luck, I'll do my dry weather dance for you!
Thank you very much for the advice and link!
Thing is I dont get why it worked for him to remove the screw and was able to move it manually and mine it wont move at all!
But yeah I will look into the fuses tomorrow, I was looking in the fuse manuals but none said sunroof but I guess I was looking at the wrong thing.
He used a big flathead screwdriver with Vise-Grips to get it open.
Im just looking up where that fuse is located. Funny enough my cigarette lighter doesn't work so im thinking it might have had its day
Also, the "special tool" they refer to is inserted to crank it closed. That may be the issue but i don't know if it is only certain years. I also have a 95 with no tool-kit.
EDIT! Looks like a hex key will get it closed for you! That is what is on the "special tool" we don't have.
Thank you very much for the picture, always helps!
Its 1 am here in the UK so I got to get to it all tomorrow morning now, but I'm going to go through a the fuses and that makes a lot of sense if there is a crank... because looking at where the screw is taken out of it also has a flat blade effect so im going to sit about playing with that and hopefully get somewhere!
Ahh well heres the fun parts, we manage to get it closed, me and my brother working together, he pulled the sunroof while I turned with a big screw driver, and we have managed to get it close but as you all may know as the sunroof closes it tilts up a little at the back, so working on that now
its so incredibly hard, doing all this we have to break it down over the couple of days as it kept killing out arms/wrists off, applied wd40 etc to help but didnt make too much of a difference.
CrackerJac
12-23-23 08:53 PM
