SC- 1st Gen (1992-2000)
Battery connections picture please
Old 10-29-12, 06:22 AM
kmoore737
kmoore737's Avatar
Default Battery connections picture please
could anyone send me a picture of the factory battery connections? I bought a non running 92 SC 400 with burned wires and I am trying to reconstruct. I think a picture is worth a thousand words. Thanks in advance
Old 10-29-12, 07:02 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
An under the hood shot? or just a whole wiring diagram
Old 10-29-12, 07:05 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
This is a picture of my SC400. (Does this work?)
Old 10-29-12, 08:59 AM
kmoore737
kmoore737's Avatar
First thank you for doing this...is there a reasonably heavy wire going from the fuse box to the POSITIVE side? In other words are there two wires to the positive side of the battery? Based on your picture it does. Yes if you have the wiring diagram I would love to have it...Thanks again
Old 10-29-12, 09:19 AM
Kohinoor
Kohinoor's Avatar
fusebox & alternator go to battery positive. engine to battery negative to chassis ground
Old 10-29-12, 09:43 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
What else do you need?
Old 10-29-12, 05:39 PM
kmoore737
kmoore737's Avatar
That helped....now I have lights and can get it to turn over and start using starting fluid. It wont Idle I assume it is because i don't have the plumbing connected from the throttle body to the filter. Couple other questions...There are 3 wires coming off the alternator do they connect to the wiring harness on the passenger side? and is the VSV associated with the PS required?
dirtfan50
02-12-17 07:21 PM
bookerdana
01-24-15 06:28 PM
Cashflo
12-14-11 02:49 PM
Lexus082
Performance & Maintenance
05-06-09 07:45 AM
mikal
01-27-06 07:27 PM
Quick Reply: Battery connections picture please
