SC- 1st Gen (1992-2000)
2JZGE Na-T TT Ecu Mod
Old 07-23-12, 10:11 AM
  #166
99SC42
gte & na-t
99SC42's Avatar
^^^^^^^^+10000000000000 exactly same map sensor no matter if it's tt , aristo or 1jzgte all 3 of them work the same way.
Old 07-24-12, 09:57 AM
  #167
Ali SC3
Ali SC3's Avatar
you guys get it running yet? if not it must be something pretty simple because mine is still running strong.
Old 07-24-12, 11:40 AM
  #168
sj408
sj408's Avatar
changing over to is300 coils and 440s and will report back...
Old 07-24-12, 12:54 PM
  #169
Ali SC3
Ali SC3's Avatar
very nice, trust me sir you will enjoy that setup.
Old 07-26-12, 01:35 PM
  #170
8052JZ
8052JZ's Avatar
Will the USDM GTE m/t ecu also work with ds62 ingnitor/ is3 coil packs/7mgte cps? I noticed on the first page it states "JDM".
Just wondering
Old 07-26-12, 01:56 PM
  #171
99SC42
gte & na-t
99SC42's Avatar
No it won't
You need to use the followings
IS300 Coils, ds62 ignitor, Aristo ecu or USDM ecu.
or
USDM ecu, tt coils, tt ignitor,tt map sensor, ait sensor and maf sensor.
You can't miss the coils and ignitor setup.
IS300 coils with IS300 ignitor or TT Coils and TT ignitor.
Old 07-26-12, 02:39 PM
  #172
8052JZ
8052JZ's Avatar
little confused you said no it wont but than say you can use the aristo or usdm ecu? I was able to find a 2jzgte ecu and map off a 6spd supra for a good price, given my SC is a 93 5spd?
Old 07-26-12, 03:57 PM
  #173
Ali SC3
Ali SC3's Avatar
YES, you can use the ds-62 ignitor with any 2jzgte ecu USDM or JDM, you just have to use the is300 coils cause ds62 is a 3 channel ignitor.
I only wrote for the JDM ecu to simplify the diagrams and wiring, and cause most people want to use a map sensor based ecu.
if you want to use the usdm, everything is the same, except you have to wire in the usdm maf and map sensor (for boost cut).
the iat is incorporated into the usdm maf, so you do not need a seperate IAT then. although you have to use a maf, it is good if you want to run 550cc injectors without a piggyback.
I am also advising everyone to stay away from 7mgte cps sensors at first, because they can cause too many issues/variables.
I have not even verified that the 7m cps works on the gte ecu (when i ran it i was on AEM), i am currently using the base of the stock distributor.
I recommend everyone uses the stock distributor, just take off the cap and rotor, fashion a new cap and you are done.
Old 07-26-12, 04:00 PM
  #174
99SC42
gte & na-t
99SC42's Avatar
all i am saying is you can miss match different ignitor with different coils.
if you wanna run tt ignitor you will need the coils to go with it.
if you wanna run IS300 coils you will need the IS300 ignitor NOT the TT ignitor
Old 07-26-12, 04:30 PM
  #175
Ali SC3
Ali SC3's Avatar
Thanks man, yes that is right you have to match the ignitor to the coils you want to use.
It is possible to use the usdm gte ecu, but its more wiring the usdm runs off a maf and also has a map sensor. you will need to recirculate your BOV with the usdm ecu, or get a VPC or a piggyback to convert to map.
the only real advantage to usdm is getting to use 550cc injectors, but i dont think the maf is worth the tradeoff.
Also, there is some debate about a "lean spot" problem on usdm odb1 ecu's but I dont know a whole lot of details on that one.
If you are on the stock headgasket and pump gas, most will not be needing much more than 440's .
Old 07-26-12, 05:29 PM
  #176
Ali SC3
Ali SC3's Avatar
Massive update to page 1, tying to get the info all in one post. i realize it was all over the place.. lol.
let me know if i missed anything.
Old 07-26-12, 08:31 PM
  #177
SixSense
SixSense's Avatar
Hey guys i know ive been kinda MIA but ive been livin the terrible,horrible,headache filled life of the GE ECU and SAFC while dealing with my Harmonic Dampener failing on me but ive got that settled now its back to the lab work i just purchased another 2jz map today for a steal $35 from a guy around the corner but thats another story haha i will be buying TT coils from him next week and if anybody needs a DS62 ignitor i have a spare for you i will do a very very good price for the sake of experimentation just make me a offer and shipping will be included. And if anybody wants to trade up i have 550rc injectors for your 440's even trade. I can post pics if need be!!!
Old 07-26-12, 08:41 PM
  #178
SixSense
SixSense's Avatar
Originally Posted by sj408
Im gonna check here in a second when im off work, Do you know if the tt ignitor and n/a ignitor are much different?
I notice in that guys video he physically cant past 2k rpm... in my car i can FORCE it to go past 4k rpms but it feels like im gonna blow some **** up. Instinctivly i let off at 4k because it falls on its face and starts going crazy. definetly gotta be ignition associated with tht code though.
Alot of other sources indicate a similar problem when using large injectors with no tuning, but it is only a 20% difference. i knew it wasnt gonna run IDEAL but i figured the comp could compensate for 5-20% difference
Thats the same exact problem i am going thru its all good at idle but it just breaks up like a teenage couple whenever i give it some gas i know it has to be mostly ignition related but if i continue to get a code for the map after i install the new sensor there might be some research to do in that area also.
Old 07-26-12, 09:09 PM
  #179
Ali SC3
Ali SC3's Avatar
welcome back, hopefully you can get it sorted out. do you have a front facing intake? TT coils wont fit under the stock intake manifold. if you have the stock intake you would be better off keeping the ds62 and sourcing some vvti coils.
Old 07-26-12, 09:21 PM
  #180
SixSense
SixSense's Avatar
Darnit lol no FFIM glad u told me before that big mistake i acutually have two DS62's picked one up to maybe help a brotha out lol i cant seem to find the vvti coils at a reasonable price tho i did find some china website with all new "denso" coils for $99 not sure if its real or not but i can place a link
here ------> http://www.aliexpress.com/product-fm...olesalers.html BTW didnt know u had a site Ali haha i kid
Quick Reply: 2JZGE Na-T TT Ecu Mod
