View Poll Results: sell it or part it
sell it whole
13
36.11%
part it out
23
63.89%
Voters: 36. You may not vote on this poll
Moving back to hawaii, sc poll inside
Alright everyone im gonna be moving back home to the islands soon and some things have changed in my plans and i wont be able to take my beloved sc with me,... so although i hate to do it im gonna have to either sell it out right or part it out to attempt to bring in a little more paper, so im in need of the advice of my fellow sc peers on this one, to part out or not? that is the question, should i part it out and dump the shell or sell it whole for less money?
heres some specs and mods to help with the voting poll..
1992 lexus sc300
105000 miles
automatic hardtop
now for the problems:
possible tranny issues, may need a converter or a flush not sure but when its cold it takes awhile to shift and is pretty jerky going into gear from park also i think the rear main is leaking slightly, also needs paint and a headliner rewrap, passenger tail light has fish in it, all but the passenger side ac vents have cracked and been removed but not replaced, ac could use a recharge, the cluster needles are sketchy but i have a set of stock needles that i was gonna send to lextech to get redone, front seats need the bottom seat trim on both sides, oh and the rims have some curb rash.
now for the good/mods:
oem parts replaced list,
97-00 front and sides purchased new from carson toyota
supra lca's
all front engine seals replaced
new plug wires purchased from pembroke pines lexus
new sway bar end links (front)
97-00 fogs and headlights (headlights are super clean)
ngk iridiums
new oem fuel filter
cat delete/resonator delete
egr delete
new gmb water pump
new high amps alternator
new optima yellow top
new front windshield
seats have been rewrapped
black door/rear side panels
third brake light delete
new trunk struts
new supra rear subframe mounts
heater delete
aftermarket stuff
walbro 255 fuel pump
boostwerx 440cc injectors
ls400 maf sensor
custom bfi
megan 3row supra radiator
mishimoto electric fans and aluminum shroud
fidanza cam gears
gates racing kevlar timing belt
trd supra sway bars front and rear
tein basic supra coilovers
megan axle back exhaust
gated shifter mod
mtec 8k hids
3k fog hids
eclipse 5510 dvd/nav
eclipse ipod adapter
eclipse back eye cam (mounted in tail light key hole)
image dynamics 5 1/4 carbon components up front
image dynamics idmax 12d2
mb quart raa2400 2ch
mb quart raa4200 4ch
rockford 3sixty.2
alumapro cap5
apexi safc2 black edition
msd 6a
msd tach adapt
msd blaster hvc2 coil
ssr strusse agile 19x8.5f 19x9.5r
wise replica wing
new nexxen3000 tires all around (bridgestone potenza s03's started getting expensive to replace every 6months)
6 dynamat trunk kits throughout the car, full trunk roof and interior of car has been matted
stoptech stainless brake lines fr, fleabay cross/slotted rotors greenstuff pads superblue racing brake fluid(rear brakes are stock but i have rotors pads and lines for the rears also, just never installed them)
fleabay turbo manifold welded in common leak spot, not installed
high beam delete with custom vents
daizen poly steering rack bushing
ati crank damper
dmax +25 fenders not installed
there's probably a lot more that im forgetting but thats about the gist of it, and there's also pics of my car roaming around here but ill through some up in this thread when i get home from work...
1992 lexus sc300
105000 miles
automatic hardtop
supra lca's
ngk iridiums
new oem fuel filter
egr delete
new gmb water pump
new trunk struts
heater delete
aftermarket stuff
ls400 maf sensor
custom bfi
fidanza cam gears
gated shifter mod
mtec 8k hids
3k fog hids
rockford 3sixty.2
alumapro cap5
msd 6a
msd tach adapt
wise replica wing
ati crank damper
thanx turbodremz, yeah it sux but i have a 86 corolla waiting for me back home which should occupy my time pretty well, but i made quite a few friends on here so im leaving the sc behind not the forum, and it looks like its 5-zip for parting it out so classifieds is gonna be my new home once i start the part out...
that would be ideal but after parting her out it would be undrivable because i dont have the factory replacements for alot of the aftermarket parts that i put in it, so its either or not both unfortunately...
also pics will be in today sorry busy day yesterday and to the people that are voting for the sell it whole poll how much do you think i could sell it for vs the amount i would make off the parts?
That would cost a very pretty penny.. Shipping to the Islands isn't too cheap anymore.. I had to leave my 98 VR4 here in Ohio when I moved to Hawaii
Thankfully I moved from there and got reunited with my 3000 again. ...Then I sold it
I lived in Waikiki/Oahu... Right off of the H2, near the NEX..I'd suggest finding a way to take it with you, all those Supras/Evo's/G35's and Hondas running around make you miss your car even more!
Good luck tho!
Good luck tho!
Aye brah, so what, you one local boy, eh? I am from Hawaii, but moved away many years ago. I visit and have a few family members left living there but very few. We all live in the mainland now. Sounds like you have put some solid work into your car.
As Scott said, parting it out will take a lot of time and effort, not just in disassembling the car, but in the process of selling the parts and shipping them. YOu will get a lot more that way, but it sounds like you do not have the time for that. I'd take it back to Hawaii myself.
GL on whatever you decide
Ryan
Ryan
as for the highlights we'll see about those, i do have another set besides the ones i have installed so we might be able to work something out
Good luck tho!
Good luck tho!
nope no typos here, just under 105000, looks like alot on paper but in the toy/lex community thats kinda like the break in period
oh and heres some pics as promised, and i also forgot to mention theres a hayden trans cooler
remotestart alarm(python871xp)
ac controls relocated to the glove box
blue leds in window contols
32 led gauge cluster(self installed)
luxurymods white led kit
and on and on and on.......................................
