SC- 1st Gen (1992-2000)
Side View Mirror not working
Old 11-06-08, 10:41 PM
WestsideSC
WestsideSC's Avatar
Default Side View Mirror not working
check kick panel fuse and it was ok. I cant get the side view mirrors to move when i press the adjustment ****.
any ideas?
92 sc400.
Old 11-07-08, 07:47 AM
AristoPra
AristoPra's Avatar
any ideas?
92 sc400.
i have the same problem and have checked all the fuses/all okay. even removed the mirror to see if it was disconnected (dropped a bolt in the panel now i have to remove it and look for the bolt, which i'll be doing over the weekend ). i have a 92 sc300 tho. . .
any help would be greatly appreciated specially while i'll be removing the panel this weekend.
Old 11-07-08, 11:32 AM
RolxuSC400
RolxuSC400's Avatar
Sorry to sound like Captain Obvious here but did you check the actual switch itself make sure its good?
Old 11-08-08, 04:00 PM
aliga
Former Sponsor
aliga's Avatar
you guys need the mirror ecu.
i have them 40 shipped
Old 11-08-08, 04:32 PM
over40driv
over40driv's Avatar
I got an ECU from Algia and it fixed my sidemirrors.
Old 11-08-08, 07:00 PM
acenase
acenase's Avatar
My side mirrors also can't move from the switch. What does this Mirror ECU do? It just plugs in under your hood? What causes the side mirrors (both side) to malfunction in the first place?
Old 11-09-08, 12:46 PM
over40driv
over40driv's Avatar
The mirror ECU is under the drivers side under dash, has 1 tricky bolt to get to, but is the controller for the mirrors after the switch.
Old 11-10-08, 07:40 PM
dwebb99
dwebb99's Avatar
you need a mirror ecu,it's a diy job
Old 03-08-10, 02:27 PM
Yrjan
Yrjan's Avatar
ECU for mirrors? so, neither drivers or passanger side mirrors on my GS300 will move up or down? They go side to side fine. Should I replace the ECU? is there on for each mirror?
Old 03-08-10, 04:40 PM
Woody426
Woody426's Avatar
Anybody have a pic of this elusive item ? I have an SC available that I scavenge parts of off, I would like to see a pic to know what Im looking for
Ken167
03-13-24 08:23 AM
IsFast3r
IS F (2008-2014)
12-07-12 08:40 PM
rave90
05-09-11 03:27 AM
MDTim
04-21-09 10:16 AM
1sxyrxy
11-27-06 11:06 PM
Quick Reply: Side View Mirror not working
