Help! Trac and engine light
Old 05-17-14, 11:37 PM
sush1a
sush1a's Avatar
Originally Posted by LeoDLion
If you are changing the O2 sensor yourself, I would just take it off and take it to the dealer.
Just changed it today, it's actually easier than changing oil.. Just gotta remove the front cover with 5 bolts and 6 clips to access the plug. The sensor has the part number on it, I just want to make sure that the sensor I took off is the bank 2 sensor 2. Now just gotta drive it for a week to see if the light comes back on.
Thank you fellas for the info.
Pupule7 (09-16-19)
Old 05-20-14, 02:28 PM
klwagoner
klwagoner's Avatar
I got the same traction off - check engine lights. Turns out the gas cap wasn't on correctly. Had to go to the dealership to get the code cleared. Never happened again. Such a waste of time to have to go to the dealership (only one in town) to get the code cleared.
Hope your issue is resolved.
Pupule7 (09-16-19)
Old 05-20-14, 04:47 PM
RX330inFL
RX330inFL's Avatar
Any of the big box auto parts stores will be more than happy to connect their scan tool to your vehicle to read any error codes and reset as necessary. Normally this is a no charge item.
Old 05-20-14, 07:33 PM
sush1a
sush1a's Avatar
I cleared my code twice already and it came back, so it was not gas cap. It might still be too early since I changed the sensor, but everything is fine still. As for part stores checking codes and resetting cel, they no longer do that in CA because of stores telling customers what is wrong, customer buy parts and it ended up being something else was bad.
Old 12-23-14, 02:15 PM
sjsperry
sjsperry's Avatar
Default Bank 2 Sensor 2 - B2S2
hi, i've read through all of the posts I could find related to the sensor. so over the weekend, i replaced what I thought was B2S2. $75 at amazon, $130 at advance auto for Denso 234-4509.
It was after the catalytic converter, but before the muffler and the sensor itself was on the passenger side. Which I thought was right side, downstream... Of note, the wire harness is really under the driver side. Then I reset the ECU by pulling the fuses, and the check engine + traction lights came back on after a couple miles of driving. So, I think I got the wrong one...
Either way, i'll put everything on this thread for future reference once it's totally sorted out. Any clarification from you guys in the mean time will help though. Can anyone confirm?
89465 in http://lexus.sewellparts.com/images/...000/84A251.jpg
The local toyota dealership is saying it's the one behind the radiator (easily accessible from under the hood). It looks like it is the same part number. Toyota 894650e010 = Denso 234-4509.
Pupule7 (09-16-19)
Old 12-24-14, 05:45 AM
Clutchless
Clutchless's Avatar
Received 1,098 Likes on 937 Posts
This may be covered under the emissions warranty which is much longer than the powertrain warranty.
Old 12-26-14, 07:35 AM
sjsperry
sjsperry's Avatar
Default Warranty
Thanks for the thought, but I didn't see the oxygen or fuel+oxygen sensors in the manual:
http://www.lexus.com/pdf/service/RX350WSG.pdf
The local lexus dealership confirmed it wasn't covered as well.
Pupule7 (09-16-19)
Old 12-31-14, 09:55 AM
klwagoner
klwagoner's Avatar
I know that the parts stores have code readers but I didn't know they could reset a code. Thank you for that info!
Actually, this happened pretty soon after I got it and since I didn't know it was likely the gas cap (except that I remember this happening to my husband with his Vette once), so I ran it back to the dealership. That won't happen again.
Old 01-02-15, 07:47 PM
chuckGS350
chuckGS350's Avatar
Your local Lexus dealership is a liar.
All sensors are covered.
Page 27, section Other Parts Used in Systems.
I had it replaced before.
Old 01-03-15, 04:36 AM
Cruiter
Cruiter's Avatar
Using the link provided below and on page 25 it appears the sensors 'may' be covered underOther Parts Used in Systems
Listed
Data link connector
(8/80)
Hoses, clamps, fittings, tubing
and mounting hardware
Malfunction indicator light and
bulb
(8/80)
Pulleys, belts and idlers
Sealing gaskets and devices
Sensors, solenoids, switches and
valves
Crossxup11
06-19-19 07:04 AM
tommy329
12-27-17 05:04 PM
jcjr
RX - 1st Gen (1999-2003)
05-19-10 03:00 PM
newgsman
02-08-08 10:29 AM
nicos1
10-08-07 12:44 PM
Quick Reply: Help! Trac and engine light
