Oil Change
Old 04-18-13, 08:07 AM
rxsuperman
rxsuperman's Avatar
Default Oil Quantity: 6.5Qt vs 7 Qt
The 2011 RX 350 owner's manual indicated 6.5 Qt with oil filter change. Will it hurt the engine if I put 7 quarts into the engine including a filter change? I noticed that when the dealer do an oil and filter change, the receipt/invoice stated they used 7 quarts but I don't know whether the dealer used half or whole of the seventh quart?
Old 04-18-13, 09:01 AM
Whitigir
Whitigir's Avatar
I do believe extra oil will hurt you engine as I stated in earlier posts. It will prematurely hydraulically lock your engine, and potentially damage other components.
I believe the dealer have to charge you 7 Quarts, because they can not charge you 0.5 as it come in a can of 1.0 each ?
Old 04-18-13, 12:46 PM
Dolphin
Dolphin's Avatar
Most dealers pump oil in from 55 gal drums....
Old 04-18-13, 01:50 PM
Whitigir
Whitigir's Avatar
Interesting, thanks for confirming. Learnt something new today. But do they have to charge you an even 7.0 ? or can they charge 6.5 ?
Old 04-18-13, 02:24 PM
heisnuts
heisnuts's Avatar
Although I am sure they can charge the 6.5 quarts, I have never seen a repair shop that does that. Every shop I have seen rounds up to the next quart even if they use less than a full quart.
So in this case, I am sure they put 6.5 quarts in and charged 7 quarts on the invoice. It is easy to check on the dip stick. If it is at the full mark, you know they used 6.5 quarts, if it is a half of a quart over the full line, they used 7 quarts and that extra oil should be drained out and put back to the correct level.
Old 04-18-13, 03:12 PM
Whitigir
Whitigir's Avatar
Awesome! thanks for the confirmation about this too!
Old 04-19-13, 11:05 AM
fwratz
fwratz's Avatar
Default Fred
Can anyone tell me how to remove the oil filter housing on a 2012 RX 450h. Is a special tool needed?
Old 04-19-13, 11:21 AM
vlad_a
vlad_a's Avatar
Very top post in the Hybrid forum:
https://www.clublexus.com/forums/hyb...ing-stuck.html
Old 04-19-13, 03:15 PM
m1964
m1964's Avatar
not likely, but rear engine seal may be damaged by the excessive oil pressure
LesR1200RT
RX - 3rd Gen (2010-2015)
09-24-18 06:15 AM
lexus-is2
10-25-13 01:57 PM
irokdastar
07-28-11 03:51 PM
maximussp
06-04-08 04:06 PM
simonsays
Maintenance
19
09-28-05 03:24 PM
Quick Reply: Oil Change
