Yellow bulb to white LED
Old 02-05-11, 06:13 AM
  #46
lesio
lesio's Avatar
Originally Posted by kitlz
Are you talking about the rear dome? I used needle nose pliers.
How did you pul the whole thing out.
Do you have any pic?
I feel silly I can't take it out
Lesio
Old 02-05-11, 11:33 AM
  #47
kitlz
No, I don't play soccer!
kitlz's Avatar
I used the pliers to take the bulb out and guide it back in since I couldn't figure out how to remove the whole dome. That was the worst of all the bulbs to replace between the cover and the small space to work in. I didn't take a picture unfortunately. Good luck.
Old 02-05-11, 12:03 PM
  #48
papaalex
papaalex's Avatar
I did not remove the whole lighting dome either. I just pry the white plastic covering of the lights similar to how you do it in the front dome lights. I used a small screw driver.
Old 02-07-11, 08:41 PM
  #49
ccwvlad
ccwvlad's Avatar
hi,
i'm trying to change the map lights in the front center. Not the middle light but the two sides(white bulbs)
when I open and take off the white clear panel, I see the bulbs are in some black box type things. any idea how to take them out to replace
can anyone help me please?
Old 02-08-11, 08:25 AM
  #50
elleh20
elleh20's Avatar
Default K level for RX350 HID conversion
Originally Posted by The X Men
You cannot change from a RX halogen setup to a RX bi-xenon set up, the high low beam circuit and mechanism are different between the two. However, you can upgrade your halogen low beam to a HID low beam by buying a HID kit, but your high beam will still be halogen.
Thank you!
~another question - what K level of HID do they normally put in the RX350s? I am between the 5 and 6Kelvin.
Old 02-08-11, 08:38 AM
  #51
Joeb427
Joeb427's Avatar
Originally Posted by elleh20
Thank you!
OEM is 4300 but I feel 5K is perfect.
Old 02-08-11, 08:57 AM
  #52
elleh20
elleh20's Avatar
Thanks! So 4300 is what would come w/ the bi-xenons...unfortunately - it doesn't look like I can replace my halogens with bi-xenons (bummer), but am going to switch to HID at least. Does the 5K light up better than the 4300? I am bummed that I can't have a high beam HID (bixenon).
Old 02-08-11, 09:03 AM
  #53
Joeb427
Joeb427's Avatar
4300 has a bit more lumens but 5K is close and produces a whiter light look.
6K has less lumens and more of a hint of blue light.
Old 02-08-11, 09:12 AM
  #54
elleh20
elleh20's Avatar
Thanks again - is there a site that best shows the difference? I had bixenons on my GS, and now I miss them! I want to get closest to what that was...although the high beams won't be possible.
Old 02-08-11, 09:16 AM
  #55
elleh20
elleh20's Avatar
one more question (for now)...would you also replace the fog lights to help w/ the high beam? If so - what would you put there?
Old 02-08-11, 09:20 AM
  #56
Joeb427
Joeb427's Avatar
The bi-xenon brights work well so I went strickly for aesthetics and used a 28 LED H11 bulb from VLEDs.
A little whiter than the HIDs a much nicer match than the yellow stock bulb.
I believe the fogs go off when the brights are turned on.
Old 02-08-11, 09:30 AM
  #57
elleh20
elleh20's Avatar
I do not have bixenon...I have halogen. So I will have to stick to halogen for high beams, correct?
I'm still learning this stuff.
Is there a site that actually SHOWS the difference between factory OEM 4300 and 5K? I did notice that I used my high beams quite often on the GS, since I loved how it lit everything up. Would the 5K give me that balance without blinding others? It is white, with no blue - correct?
Old 02-08-11, 06:46 PM
  #58
papaalex
papaalex's Avatar
Here is a comparision of the different kelvin temp.:
Nice color comparison pic X Men I didnt know they had green and red HIDs
Old 02-10-11, 02:13 PM
  #59
onefastdoc
onefastdoc's Avatar
Wow, that was a really awesome post. That takes a lot of time to replace all those bulbs, photograph it, then post it. Very helpful to the Lexus community. Thanks again.
Old 03-17-11, 05:32 PM
  #60
sweetboy02
sweetboy02's Avatar
Thanks, just replaced the front dome lights.
How can we replace the Puddle lights? Just pop out the plastic cover too???
Quick Reply: Yellow bulb to white LED
