windshield crack
windshield crack
my windshield got hit by little rock in the highway, and it crack.............
about the nail size, in the lower right.
I wonder will car insurance companies replace the windshield even though i dont have full insurance? I heard that windshield is coverd in basic.
And my wiper blade is automatic (I dont know will is the sensor located), I wonder it will still be automatic after replace the windshield.
Thank you
Thank you
my windshield got hit by little rock in the highway, and it crake.............
Thank you
Thank you
In the mean time put a piece of mending tape over the crack to keep dirt and moisture from getting in.
Many insurance companies will cover the cost of a chip repair for free. Check with your agent ASAP. If the chip is not too large and you have it corrected quickly the repair will be nearly invisible and will last indefinitely. Most come with a lifetime warranty.
I had mine repaired bacj in July when I completed a 5000miles trip to natinal parks. The crack was about a nail size and the repair was perfect. YOu don;t even notice it at all after the repair. The rain sensor is at the middle top of the windshield you can see a meshed ares there. My crack was at the middle bottom so the repair work doesn;t impact the rain sensor at all.
I have fill insurance so that the repair is fully covered. Get it done ASAP before temp goes down.
Small cracks and chips can be repaired and it's usually safer than having the whole windshield replaced. I've heard of cracks as large a 3-4 inches being repaired in this manner. The process drills a small hole or two to relieve any tendency for the crack to enlarge and uses a tool to evacuate all the air. Next a thin liquid resin is added which is sucked into the crack/chip then hardens. The pressure is relieved so the chip or crack usually will not expand and the resin makes it disappear. Works quite well and as I mentioned, most insurance companies cover this at no cost.
New OEM windshields can cost over a grand to replace.
If they do have to replace the windshield, I believe it is heated where the wipers rest. Make sure that the repair tech installs it correctly.
I had a Toyota Highlander with a heated windshield which needed replaced. To save time, the tech cut the leads and installed the glass without me knowing it. Found out a few years later when it needed replaced again.
It's more difficult to install correctly as the cowl needs to be removed to get to the wires.
Good luck and call your insurance company now!
had my windshield repaired for free by my insurance company. This week on my way to Vegas some one threw out there window a nice heavy metal object. Amazingly the windshield only cracked. First visit was a repair and he told me I was going to still see the crack a bit. So $100 deductible and a few hrs wait and new windshield was on. Most of these guys from the national window repair/replacement companies are pretty knowledgeable and he took everything off and put it back on correctly.
In fact it was dam right one of the easiest car related mountains into mole hills I have ever had.
Thank you
Thank you
Yeah my auto rain sensor is all wacky and my AC kind of was all warm for a while today till I made it below 70. Grrrrr and there is definitely a new air leak some where. Guess I need another visit for them to fix it.
JoeJ
07-10-06 09:21 AM
