Electrical or ignition?
Used the key to lock the car and noticed headlights werent turning off. Fifteen min. later, tried to start the engine and the ignition switch was locked and wouldnt budge (even though the seat and steering wheel memory ops kicked in). Cant check for a diagnostic code if I cant at least turn the key to accessories and dont even know if that would help.
This sounds like a Steering Wheel lock. I'm told it is a feature on all cars. Try turning and shaking the key in the the ignition while tugging on the steering wheel to release the lock. In my case I had to tug the steering wheel several times pretty hard to get the key to turn. This "lock" triggers when the steering wheel is turned while the keys are out of the ignition, I believe. Don't know what reason this was designed for though as it seem a nusiance.
I've been told that you might also put the car in neutral and push it a couple feet and the lock will release too. I've not tried this though.
Wont budge
Thanks, I tried. I cant get anything to budge. It's an automatic tranny. The the shifter is in Park and wont budge. Tried turning the steering wheel in both directions while attempting to turn the key- wont budge. I cant depress the brake pedal to the floor either.
Getting on a soap box ... so skip if not interested specially when the OP's problem is solved.
Ignition key provides lots of functions ..
1. Wake-up (prime system) when you insert the key.
2. Steering lock release (first detent) Jim wanted to know why ...
It is to prevent some one to hot wire the vehicle (legacy).To kill the engine a certain wire is set to ground. Conversely to run that wire is not set to ground. So hot wiring procedure is to disconnect the wire and then send 12v to the starter and that gets the engine running. Expert thief can accomplish that within less than 30 sec once (s)he enters the vehicle. To prevent thieves from driving the vehicle, the added security feature was added to lock the steering [the ignition switch is right there and all it needs is a little cog to jam it]. The cog is flipped by the key, but then the steering must be turned by a certain angle to get caught up in the cog. If the steering wheel is left straight on, the system is not jammed up. If you turn the wheel [typically is done by kids who do pretend driving] the dreaded jam-up happens. What is needed is some relief and you do that by simultaneously turning the key and turning/wiggling the steering wheel.
3. Acc ... boon to the person(s) waiting in the vehicle for their entertainment.
4. Run/on. Fully functional mode ... self test of idiot lights before starting.
5. Start. Once again safety needs to be ensured. Transmission needs to be in park (exception Neutral). This is where the gear lever position interlock switch plays a part. NC5wes mentioned this.
Some time rocking (pushing) the vehicle can help the steering move to release the jam-up [it takes less effort to turn the steering wheel when the wheels are spinning] and also jerks the gear lever interlock.
*The engine imobilizer is the new way to prevent hot wiring.
Salim
PS: After a nights sleep, I think we still need the steering lock. This would help when "good drivers" curb their wheels. The steering lock will prevent the castor from straightening the wheels when and if the vehicle starts rolling.
Bonus points for "good drivers" who curb their wheels.
S
Salim
S
ShowGSLuVv
06-16-02 08:51 PM
