Help me understand "module that drives the four-pin trailer plug"
Old 11-26-09, 08:34 PM
whirlygig
whirlygig's Avatar
Default Help me understand "module that drives the four-pin trailer plug"
I have just easily installed a Lexus Hitch on my 2004 RX and plugged the wiring harness into the prewired connector under my rear compartment.
I am getting no lights on the trailer.
I did a search and saw where someone did a similar install and had no power. A poster mentioned a module to drive the connector?
Can anyone explain where and what the module is that drives the 4-pin trailer hitch plug?
Old 11-26-09, 10:03 PM
whirlygig
whirlygig's Avatar
I have come across this part number on another web site for an electrical converter needed when you have no tow package.
electrical converter is necessary - P/N 82670-48050.
Can't get a match on Google.
Old 11-28-09, 05:38 AM
kiwi
kiwi's Avatar
could you not just remove one of your taillights and splice into the wiring??
Old 11-28-09, 07:09 PM
voodoojc
voodoojc's Avatar
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).
Old 11-30-09, 03:58 PM
whirlygig
whirlygig's Avatar
Could splice in and that is what I may be left with doing. have found that Lexus randomly left off the converter module (which does the same thing) on some RX's, even those with "TO" package.
Thanks for the diagram voodoojc.
Old 12-01-09, 06:34 AM
geko29
Super Moderator
Senior Moderator
geko29's Avatar
Careful with this. A friend of mine had a hitch installed by U-Haul on his 2006 Jeep Grand Cherokee and they spliced instead of using the special box that you're supposed to. Wound up putting the truck into limp home mode (locked into 2nd gear/most idiot lights on) and cost $1800 to fix.
Old 12-01-09, 06:49 AM
aquatrax
aquatrax's Avatar
Does anyone know the voltage the RX uses for the lights and is it the same for a trailer?
Old 12-01-09, 07:36 AM
lexus114
lexus114's Avatar
Don`t you have to plug in a fuse or something in the fuse box? Thats how it was on the first generation RX.
ibidu1
05-09-19 02:36 AM
windssmith
NX - 1st Gen (2015-2021)
08-26-16 03:47 PM
ddawsonis
10-28-07 10:01 AM
Ntwrks1
GX - 1st Gen (2003-2009)
09-22-07 08:47 PM
lexbuddy
03-12-06 04:08 PM
Quick Reply: Help me understand "module that drives the four-pin trailer plug"
