Problem with sunroof
Old 11-28-07, 09:14 PM
matchstick
matchstick's Avatar
Default Problem with sunroof
The title tells it all. I am having a problem with my sunroof. For some reason the one touch sunroof button is not working. I can only open and close the sunroof if I hold the switch. I was wondering if there is anyway to reset or reprogram the sunroof back to one touch.
Thx
Wilson
Old 11-28-07, 09:20 PM
Booyah
Booyah's Avatar
Yes there is and its in the manual. I do not know it off the top of my head
Old 11-29-07, 05:32 AM
jfelbab
jfelbab's Avatar
Turn on the ignition and press and hold the "Tilt" button. Keep it depressed as the roof tilts up and down and then opens and closes. Then you can release it and the automatic function will be reset.
Old 11-29-07, 06:30 AM
The G Man
The G Man's Avatar
Try reprogramming the auto function. Open the sun roof all the way and hold the button for 3 to 4 sec., then do the same when you close it. That should do the trick.
Old 11-29-07, 02:28 PM
teamtbo
teamtbo's Avatar
jfelbab and G are correct.
According to TSB PD004-04 (Initialization of Moon Roof):
As a result of the removal of the Short Pin, the “one–touch tilt up and down,” “one–touch slide open and close,” and “jam protection” functions of the moon roof will be inoperative due to loss of the moon roof position memory stored in the microcomputer. Therefore, initialize the moon roof by following these procedures:
1. Turn the ignition switch to the “ON” position.
2. Push and hold the moon roof switch to the “TILT UP” side or the “SLIDE–CLOSE” side until the following cycle of the moon roof operation is completed:
A. Closing
B. Fully tilt up
C. Fully tilt down
D. Fully slide open
E. Fully slide close
3. After the cycle of operation above is completed, the initialization is completed.
4. Check for proper operation of the “one–touch slide open and close” and “one–touch tilt up and down” functions by pushing the switch briefly to the “SLIDE OPEN” and “TILT UP” positions.
Old 11-29-07, 06:30 PM
matchstick
matchstick's Avatar
Thanks for everyone info. Its actually work.
Old 11-29-07, 09:03 PM
Crystal_RX
Crystal_RX's Avatar
Club lexus rocks. It is place where you can find all the tricks that work for your car.
Crystal White RX350
Old 11-30-07, 08:10 AM
Rollin'ES3
Rollin'ES3's Avatar
My RX is doing the same thing....no auto. I was about to post a thread asking if the RX had one touch for the sunroof. I'm gonna try this tonight.
Old 11-30-07, 11:40 PM
Rollin'ES3
Rollin'ES3's Avatar
Problem solved. I love this place
Old 05-03-14, 10:56 PM
bmeier8579
bmeier8579's Avatar
Default Fixed the sunroof
Oh my goodness it worked. THANK YOU!!
Old 05-04-14, 03:04 AM
Nozzleman
Nozzleman's Avatar
I didn't even know that it had one touch. I have been struggling without it for a year now. My Envoy has it and was disappointed that the Lex was so difficult to operate.
Thanks for the reset!
Old 05-04-14, 04:05 AM
RX330inFL
RX330inFL's Avatar
Just like the window controls, the sunroof needs reset any time the battery has been disconnected or changed. All this is in the Owner's Manual.
Old 05-04-14, 04:13 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
^And one touch stops working when the battery is on the way out. That's one way to know it's time.
k2au
01-06-22 01:16 PM
Naserals
LX - 3rd Gen (2008-2021)
04-24-15 05:31 AM
RLGS300
IS F (2008-2014)
04-13-14 11:28 AM
ShawnD
01-14-14 08:41 AM
HimSelf
09-25-13 07:51 AM
Quick Reply: Problem with sunroof
