Transmission / Cooler Question
Old 08-08-14, 05:00 AM
pilot2
pilot2's Avatar
Default Transmission / Cooler Question
I would like to be able to pull a 1200 lb trailer with my 2000 RX300 AWD. In addition to the stock trans cooler which is installed--like the unit below--did Lexus do anything additional to enhance the transmission cooling when they installed a tow package?
Old 08-08-14, 04:01 PM
AnthonyMtz
AnthonyMtz's Avatar
Unfortunately no, that's why the rx300 has cut outs on the bottom of the bumper to enhance air flow, if you would like you can install a small 7 or 8" auxiliary cooling fan witch has about 650-750 cfm's. That should be plenty of air flow to be ok all you have to do is wire it up to a relay and then to a on/off switch so you can have it on or off as you please
Old 08-09-14, 07:28 AM
Lexmex
Lexmex's Avatar
The crappy thing about even about that location is that the windshield wiper fluid reservoir blocks a good part of that cooler from getting air through that hole on the bumper and that's the reason many years ago I ditched the windshield reservoir altogether, but the fan would be the only other way or if the cooler could be relocated in front of the reservoir.
I posted photos of the area in this thread, https://www.clublexus.com/forums/rx-...n-failure.html
Old 08-09-14, 02:02 PM
pilot2
pilot2's Avatar
Originally Posted by Lexmex
...I ditched the windshield reservoir altogether...[/url]
Did you replace the reservoir with a smaller one or you just have no reservoir?
murphysf
05-17-19 04:23 AM
Talons24
03-09-19 06:18 AM
boo1678
03-19-13 11:15 PM
racey02
03-23-11 06:09 AM
rx300ownde
01-27-08 05:22 PM
Quick Reply: Transmission / Cooler Question
