My driver rear door does not lock
Old 01-06-14, 05:10 AM
Stemmer
Stemmer's Avatar
Default My driver rear door does not lock
I tried to search the answer and found this DIY: https://www.clublexus.com/forums/rx-...-write-up.html
I am not handy and want to make sure the parts noted in the DIY are what I need - I would have my indy install. The issue is that when I lock my doors either with the door lock button or with the fob all doors lock except the passenger rear door - the lock does not move. I need to manually lock it. The lock does unlock, however, with either the door lock button or the fob, it just does not lock. Is this my issue in the DIY link or another problem? Thank you for any help.
Old 01-06-14, 05:14 AM
Z07
Z07's Avatar
Very likely.
But no one can tell until the door panel is off.
I replaced two of those motors on my LX for the exact same symptom you described, unlocks fine but won't lock under power. The brushes on the motor I took apart were shot which made no sense because it uses power either way. I suppose there is some more conducive mechanical advantage in the unlock mode maybe.
FWIW I bought four of the motors off of eBay for $20 (5 ea).
Old 01-06-14, 06:46 AM
hypervish
hypervish's Avatar
Yup, that's what you need to do!
Old 01-06-14, 03:03 PM
Stemmer
Stemmer's Avatar
Default Thank you!
Thanks for both replies. I'll order the parts and have it done with my next oil change.
Abernoots
10-21-22 06:27 AM
jonathanrn
01-30-18 11:01 AM
Aristo722
02-16-14 09:44 AM
P Rock
02-03-14 08:08 PM
rkoz
09-05-12 06:35 PM
Quick Reply: My driver rear door does not lock
