ATF IV using as Power steering fluid?
Old 07-01-13, 10:20 AM
dbui
dbui's Avatar
Default ATF IV using as Power steering fluid?
Can I use Toyota ATF IV from my transmission for the Steering fluid? I would like to flush and fill the power steering.
Old 07-01-13, 10:26 AM
hypervish
hypervish's Avatar
Yes, that is what it's spec'd for!
You can also use Mobil 1 ATF.
Old 07-01-13, 03:42 PM
mckellyb
mckellyb's Avatar
Sure can. It's the same stuff.
Power steering fluid is just lightweight oil. That systems isn't particularly picky about the oil used, as long as it's light, unlike transmissions.
Old 07-01-13, 04:33 PM
salimshah
salimshah's Avatar
There are exclusions ,,, like Honda insists on using Honda Steering fluid only.
If I am not mistaken, for RX you can use Dexron for steering pump. Toyota type IV can be safely used too. Although I prefer and use the synthetic mobile 1 Atf.
Salim
Old 07-01-13, 05:27 PM
carguy07
carguy07's Avatar
I would have to dig for where I saw it, but I'm almost positive that Toyota/Lexus specifically says to not use T-IV, only Dextron. They are a little different.
Old 07-02-13, 04:12 AM
dbui
dbui's Avatar
Ohhhh man Carguy07 if you find it can you post it thanks! I did the power flush yesterday, might have to do it again if the ATF IV not compatible. Brake fluid flush and fill next.
similar engine for power steering flush and fill.
Old 07-02-13, 09:30 AM
lexus114
lexus114's Avatar
You need to use Dextron fluid in there.
Old 07-02-13, 09:47 AM
hypervish
hypervish's Avatar
I stand corrected.
It is spec'd for Dextron, according to the owner's manual.
However, many people on this forum are using T-IV or ATF compatible with T-IV such as Mobil 1 ATF.
It is completely safe to use T-IV in the power steering system.
Old 07-02-13, 11:14 AM
lexus114
lexus114's Avatar
I stand corrected.
Yup, I use the Mobil-1 in mine. Works very well.
Old 07-02-13, 06:26 PM
carguy07
carguy07's Avatar
I can't find where I saw it, I think it was something to do with warranty claims on RX330's that were running T-IV, not sure how they would know the difference.
Mobil 1 specs for Dextron, so is basicly is Dextron.
Old 07-02-13, 07:11 PM
Lexmex
Super Moderator
Lexmex's Avatar
Been using Mobil 1 ATF for this purpose for a long time
Old 07-03-13, 04:30 AM
hypervish
hypervish's Avatar
For comparison sakes, T-IV is also basically Dextron if you want to go with the core components, since T-IV is just Dextron III plus friction modifiers.
SeattleGS400
Maintenance
52
10-13-19 07:42 AM
nparthi
02-03-19 08:04 PM
babyduke
ES - 5th Gen (2007-2012)
08-24-18 12:33 AM
TriniLex
RX - 3rd Gen (2010-2015)
04-03-18 03:08 PM
hlu1
IS - 1st Gen (2001-2005)
02-22-13 11:53 PM
Quick Reply: ATF IV using as Power steering fluid?
