Minor problems on new rig
Old 11-21-12, 11:19 AM
Ramblemutt
Ramblemutt's Avatar
Default Minor problems on new rig
Got my comprehensive inspection on my 5 day old, 400 miles....2K RX. AWD, 114K miles. New forward struts needed, power antenna, right front passenger window motor malfunction (it works part time, worked fine when I bought it), 2 small rock chips in windshield and finally, "d" tranny light in instrument cluster is out (I understand this is not uncommon, or maybe there is no light).
All in all, not bad and relatively easy fixes. Not sure about that d light...can live without, of course.
Anyone else solved this problem inexpensively?
So far so good. Comfy, solid, and plenty of power for my mountainous environment. Came with a new set of BFG Long Trail T/A....not my choice of tire, but will do for a while and will handle the snow without my having to invest in snow tires......I've run them before a few years back.
Went thru and changed all fluids, going with M1 in the engine. All the drained stuff looked good. Will gladly accept any ideas, advice to keep this guy in the air. Thanks, all.
Old 11-21-12, 12:02 PM
Dadikins
Dadikins's Avatar
The "D" light is probably the easiest of all to fix. I'm not mechanically inclined, and even I was able to do it.
This thread that gives detailed instructions.
https://www.clublexus.com/forums/rx-1st-gen-1999-2003/77510-instrument-cluster-drive-gear-indicator-light-out.html
Your right window could either be a bad switch on the window itself, or a bad master switch. I've had the rear back window go down at random, and then not be able to put it back up for a few minutes (my master switch is bad). I bought one from a salvage vehicle, but haven't tried to install yet.
I just keep my window lock switch pushed down most of the time - problem solved. :-)
Old 11-21-12, 12:35 PM
salimshah
salimshah's Avatar
Originally Posted by edit snip edit
Will gladly accept any ideas, advice to keep this guy [COLOR="DarkOrange"
in the air.[/COLOR] Thanks, all.
Nooo. For vehicles .. in the air ,,, means on jack-stands
Welcome to CL
Salim
Old 11-22-12, 09:19 AM
Ramblemutt
Ramblemutt's Avatar
Welcome to CL
Salim
Sorry...you're right. I'm an old US Navy flyer, hard to get it out of the system.
Thanks for the info DanDevoe...yes, I keep the lock down too. Window does not work with either switch and when it finally does go up, it is very slowly. I can hear the switch engage, just no motion. Just have to tear it apart and have a look..
JasDmw
02-17-14 04:47 PM
corradoMR2
RX - 3rd Gen (2010-2015)
16
01-14-14 08:47 AM
viperdoc
12-05-13 01:16 PM
lexus114
02-14-12 09:45 AM
SkyHigh
09-19-02 02:18 PM
Quick Reply: Minor problems on new rig
