interior lights
Old 09-14-10, 06:11 PM
oneshote
oneshote's Avatar
Default interior lights
Interior lights do not come on when door is opened
Bulb works
Old 09-14-10, 06:32 PM
bob2200
bob2200's Avatar
Does the "door open" indicator on the dash light up? Have you checked the fuses?
Old 09-14-10, 06:39 PM
oneshote
oneshote's Avatar
Thanks for the help, I will try that
Old 09-14-10, 06:51 PM
bearbrew
bearbrew's Avatar
You may want to check the door switch and verify its condition and operation.
Old 09-15-10, 09:29 AM
oneshote
oneshote's Avatar
Checked fuse
working order
Rear seat interior light comes on
but front does not
Old 09-15-10, 09:57 AM
bob2200
bob2200's Avatar
Great! There is a 3-position switch: On, Off, and Door-open-controlled. Does it light in the On position? It it doesn't work in On position, I'd pop the cover (like to remove bulb), unscrew it, and check to see that you have 12 volts on the wiring.
Old 09-16-10, 11:49 AM
bob2200
bob2200's Avatar
My RX300 has a different roof layout (no moonroof), so I don't have any light between the 3-way switched light and the map light. If you can measure voltage, I'd remove the light that doesn't work and measure to see whether or not you have 12 volts on the wires. Give the forum a few more days. Additional roof lighting is not an essential function.
Old 09-16-10, 11:54 AM
hypervish
hypervish's Avatar
I've never seen a RX300 without a moonroof. Can you please post a picture? I'm interested to see how it looks.
Old 09-16-10, 05:26 PM
bob2200
bob2200's Avatar
Here it is. The "wart" in the middle of the roof is my XM satellite radio antenna.
Old 09-16-10, 06:07 PM
hypervish
hypervish's Avatar
Thanks...It looks pretty much the same, I think the roof has a more visible slope like this.
Old 01-20-11, 10:15 AM
thejanitor
thejanitor's Avatar
was there ever any fix for this? rear light comes on and front light works when i switch it on just not when door opens. Can you change dim level of interior lighting/dash etc.
waeltzy
ES - 5th Gen (2007-2012)
09-05-12 03:01 PM
Deucerwild
RX - 3rd Gen (2010-2015)
06-20-12 11:08 PM
Emilio253
SC- 1st Gen (1992-2000)
13
02-21-11 07:02 AM
daweeze02
09-14-10 10:20 AM
jacky28
10-23-06 03:08 PM
Quick Reply: interior lights
