Code P1354 Help Please
Old 05-04-13, 03:44 AM
JAB
JAB's Avatar
Ididit: The device has a robust o-ring. Wiggle it back and forth while pulling straight out; it should come.
Old 05-04-13, 03:32 PM
ididit
ididit's Avatar
Thanks. already got it done by using a basin wrench. quite easy.
UPDATE: it turns out that the bank I first pull out by basin wrench is bank 1. I just pull out the bank 2 by hand, just like what you describe. Thanks for your tip.
Old 11-24-13, 12:18 PM
tadpole666
tadpole666's Avatar
Hello, I am new to the lexus rx 300 but i am not a newby at mechanic work. I have had the same code(p1354) and I replaced both OCV valves this morning and now that code is gone and I have two new ones, p0125, and p1133. My rx 300 started with twelve codes at first and i have replaced the thermostat, radiator, and coil packs with new spark plugs as well. I have been going down the list one code at a time. I have also changed the oil and filter and checked to make sure my fans are running good, but the vehicle is still getting hotter than normal. Can anyone help?
Old 11-25-13, 06:52 PM
ATLs460
ATLs460's Avatar
Just this morning I had p1354 in addition to random multiple misfires on cylinders 2, 4, and 6.
7 codes total
2 for each cylinder misfiring and 1 for the 1354
Brakes lost their boost and were stiff/weak
When in neutral engine rev'd to 1300rpm
At a stop the engine vibrated like crazy
Lost overdrive and essentially went into limp mode
CEL blinked every now and again but was always on.
I bought a new "left" OCV (oil control valve) and it runs like new again.
If you have these codes and symptoms...replace your OCV and 99% chance you'll have taken care of the problem.
Old 11-25-13, 06:54 PM
ATLs460
ATLs460's Avatar
How old is your water pump?
It's also ALWAYS possible to have a defective new thermostat. I've seen it happen more than once in my 15+ years of wrenching.
Old 11-25-13, 06:56 PM
ATLs460
ATLs460's Avatar
Originally Posted by carlover
FYI - I've learned to goto the Toyota Dealer (not the Lexus), tell them I have the 1MZFE engine in my 2000 ES300 and they get me Toyota OEM parts cheaper than the Lexus dealer. On the first few visits to the parts dept, most of the counter guys didn't know what I was on about, but now I've taught them a thing or two and they know which models match and have been able to help others.
It's sad that you have to school a Toyota parts guy on the endless cross references between our Lex's and similar Toyo's.
Old 11-28-13, 06:45 AM
JusJuju
JusJuju's Avatar
I had this same issue. Did you replace your air filter? Because the air intake is above 3 of the back 3 spark plugs. When they dont get enough air it throws off the valve timing and causes a laundry list of problems.
Old 01-05-14, 10:31 AM
lostape45
lostape45's Avatar
Default 2001 Es 300 issues
Hello everyone,
New to the forum and new to repairs here but i recently had a very similar issue as @erics99rx except minus the overdrive issue. I was hoping someone could explain to me where I find the ocv and the ocv filter and how I go about replacing/checking them for damage.
Thanks
Old 01-05-14, 10:34 AM
salimshah
salimshah's Avatar
There is a list of DIY (sticky) and you will find the right link in there. Although core engines are the same, access and other things may be different.
https://www.clublexus.com/forums/rx-...x300-diys.html
Salim
Old 06-03-14, 11:50 AM
vishesh
vishesh's Avatar
Originally Posted by Planeguy
Don't know if it's frowned upon to give details, but I ordered the part from Partsgeek because RockAuto and none of the local guys had one. So you know, they call it a Cam Adjust Solenoid on there, but they mention Lexus calls them OCVs. They also say "left" or "right" for the parts description and not the bank numbers. Bank 1 is the solenoid on the right, and nearest to the firewall. Bank 2 is the left solenoid, and closest to the radiator. It was $63 with free shipping and a genuine Lexus part showed up, not too bad. I saw some other guys paid ~100 at the dealership so I sprung for the cheaper one.
Got the part in today, it took about 10 minutes to pop in there and tighten the retaining bolt. The car immediately ran great, highly recommend this job as a DIY. Thanks again guys for the good info, hope I helped someone too.
Just want to clarify: I think RockAuto does in fact offer this part. At least for a 1999 Lexus RX300, it's listed under Engine > Variable Timing Solenoid.
Old 02-24-18, 12:31 PM
LA4Mead
LA4Mead's Avatar
Default P1354, Brakes, No apparent misfire.
Good information here. My '99 RX300 is well, self maintained with frequent and a recent oil change, 19x,000 miles, without apparent sludge. Timing belt was around 130,000. I have not yet removed the oil control valve. The PCV valve was replaced about 10,000 miles ago, but was not sticky. My symptoms that suddenly coincided with the P1354 code are that the engine was a bit sluggish at the time and the brakes needed a bit more effort. The CEL came on and stays on, no blinking. There are no other codes or pending codes, and I haven't had many trouble codes on this car.
Does it seem that it could be something other than the oil control valve? Timing or belt? Could this be a vacuum leak? What should I look for? Which OCV if so?
Thanks for your help!
TCAL
12-04-12 07:37 AM
kngkong
Maintenance
05-31-11 05:41 PM
02msmg3
12-13-10 11:47 AM
vugoodoll
Performance & Maintenance
12-07-06 05:30 AM
Quick Reply: Code P1354 Help Please
