RX300 - Remote Question
can anyone help me with my non working remote?
I have learned how to program but at very last step where you press "lock and Unlock key" the red light blink fast and kept blinking until I release the button and transmitter does not get programmed.
Is it a bad remote?
Can buy a new key from ebay and have them cut it? Will I be able to program transmitter without master key?
Dealer is asking $300 and that's insane.
Is it a bad remote?
My understanding is that you are trying to program a master key without the use of another (working) master key. From what I've read, that is your problem.
Again, from what I've read here on the forum, if that is the case, $300 is unusually cheap.
[QUOTE=bob2200;3458429]My understanding is that you are trying to program a master key without the use of another (working) master key. From what I've read, that is your problem.
x2
That is the case with almost all "chipped keys"- it takes 2 functioning programed keys to program an additional key. If you only have 1 key, the dealer or a very good Lexus experienced locksmith are your only hope. And God help you if you lose both keys for a Lexus!
x2
Just so we don't panic Trader2K too badly, I don't think it's that bad. I think it only takes one working master key to program additional master keys. Also, I think you can readily get a Lexus key cut by a mail-order or regular Lexus dealer from the VIN number (upon proof of ownership). The remote features are nice, but not essential. People survived for many years using only the lock cylinders.
Once you figure out exactly what you have, sites like this can get you going much cheaper than the dealer.
http://www.toy-lex.com/index.html
Hi- I called Lexus before to get another key made, because I only have 1 master key. I've also checked ebay. I don't think you really save that much if you buy it from ebay because a lot of keys there for auction don't have the brain in the key and if it does it's only about 50.00 cheaper. Plus ebay way you have to get the key laser cut and programmed which I think is 150.00 or so. Lexus said for the key, cut, and program it's about 300.00. Hope that helps
Oh, for your last question about not having a master key. The dealer said if I lost both keys, it would cost about 1000.00 to change the computer inside the car then make another master key.
Fellows thanks for your input. I do have one key that I use for start and stop but remote is not working as I said in my original post.
Can someone post instrcutions for "how to program RX300 remote"?
When you all say master what do you exactly mean? I think the key I have right now which works fine except remote can be called a master key, if not then what is it?
Thanks.
Thanks.
Thanks.
Thanks.
Here are the programming instructions:
http://www.toy-lex.com/programming11.html
