Used Purchase advice
Old 03-11-22, 09:11 AM
Glenny
Glenny's Avatar
Default Used Purchase advice
Hey
I'm new to the forum and new to Lexus
Hoping someone can give me some advice
I'm looking to purchase a 2003 Lexus RX300 with 150k miles on the clock
It's a reputable online car sales business and they do a roadworthy check and list and issues.
It looks in real good condition overall. It drives well. No smoke from the exhaust at all.
However there is one thing I am concerned with in the pic below.
It seems there is a bit of sludge on the inside of the oil cap.
It does not have a milky colour though.
Is this ok or should I be concerned the head gasket is on the way out?
I will add that when they bought the car, the oil level was very low.
Thanking in advance!
Old 03-11-22, 05:26 PM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,101 Likes on 991 Posts
Check the thread on loss of oil. If there is no leak the oil can be sucked in through the air intake via PCV.
Salim
Old 03-12-22, 12:37 AM
Glenny
Glenny's Avatar
Default SLudge on oil cap?
Salim
Thanks Salim!
Yes I am aware of the PVC problem.
My main question is.. does that sludge on the bottom of the oil cap look normal as it is not milky yellow or white?
Thanks!
Old 03-12-22, 07:32 AM
salimshah
Forum Moderator
salimshah's Avatar
That is not sludge. It is crusted oil vapors. To determine if there is sludge, you will have to remove valve covers and examine if tar like substance has pooled up there. You can also check the oil pan too.
Salim
Old 03-12-22, 08:43 AM
Glenny
Glenny's Avatar
I was worried the head gasket might be on its way out.
It has 150k miles on the clock.
Apparently the engine starts first time and purrs.
Would your opinion be that looking at the oil cap deposits that the head gasket is ok?
If the previous owner did an oil change, how long would it take for the oil to go milky if the
head gasket was damaged?
Thanks for your help!
Old 03-12-22, 10:47 PM
salimshah
Forum Moderator
salimshah's Avatar
Why the narrow concern about head gasket and oil-coolant mixing? Did the engine overheat? Are you observing bubbles through the radiator cap? Is the dipstick showing milkshake like substance instead of oil.
Salim
Old 03-13-22, 01:32 AM
Glenny
Glenny's Avatar
Salim
My only reason would be the sludgy substance on the oil cap..
I can't say if the engine overheated.
There is no oil in the coolant.. However the coolant looks pretty new so could have been changed recently.
There is a slight bit of water coming out of the exhaust but I think that's pretty normal condensation.
No bubbles in coolant. No smoke from exhaust. The dipstick is clean but could also have been wiped clean...
Any thing else I should look out for?
Old 03-13-22, 07:49 AM
salimshah
Forum Moderator
salimshah's Avatar
Oil cap --> already answered
Any thing else --> Have a mechanic check the vehicle out. Suspension, compression, transmission
History --> check the records or ask the seller .. why was the coolant changed, timing belt, water pump.
Upcoming maintenance items: Tires (age/wear), timing belt, valve cover gasket, driveshaft boots, battery, brake fluid, steering fluid, interior leather
Salim
Old 03-13-22, 11:40 AM
Glenny
Glenny's Avatar
Salim
Yes I think that is the best idea to have a mechanic check the car out.
Thanks very much for you help!
Old 03-15-22, 08:38 AM
sktn77a
sktn77a's Avatar
^^^^^^ That crud on the oil cap is quite normal at that mileage.
Old 03-15-22, 11:22 AM
Glenny
Glenny's Avatar
Thanks very much!
Old 04-03-22, 06:59 PM
Felix
Felix's Avatar
Nothing to do w/ a H/G or coolant in the oil......Pulling that front v/c off you'll show you a good posibly of a plugged pcv & possbly the PO didn't change the oil soon enough........
Old 04-04-22, 07:52 AM
rooster1
rooster1's Avatar
original poster must have owned a few subarus. these cars do not have head gasket problem. 150k is nothing.buy it or I will iwill
The following 2 users liked this post by rooster1:
farmer33 (04-04-22), GHBabie (05-28-22)
Old 04-04-22, 03:08 PM
farmer33
farmer33's Avatar
Check this YouTube video by speedkar99. He shows a sludgey oil cap but it is clean as a whistle under the valve covers.
cbrf23
45
11-27-22 09:36 AM
Nuadha
10-09-21 09:54 AM
2011ct
CT 200h Model (2011-2017)
08-07-21 10:34 PM
OneSicSRT
05-01-11 04:04 PM
shark13
38
08-14-10 08:16 PM
Quick Reply: Used Purchase advice
