Crush washers for diff/transfer etc.
Old 12-15-07, 11:07 AM
carguy07
carguy07's Avatar
Default Crush washers for diff/transfer etc.
Getting ready to do my fluids. I think I am reading conflicting things regarding the plug gasket/washers for the different plugs.
Can someone confirm this stuff up?
Rear Diff, takes 2 crushable aluminum washers? Someone said steel in a post?
Transfer case, 2 crushable aluminum washers?
Trans pan and front Diff, no washers?
Thanks!
Old 12-15-07, 11:27 AM
salimshah
salimshah's Avatar
Received 1,007 Likes on 910 Posts
Diff has a fill and a drain hole. So 2 washers... tip open the fill hole first [just in case there is a problem you are not left stranded ... drained oil ]
Trans pan drain hole 1 washer
Transaxle 1 drain hole 1 washer. [Fwd]
All washers are aluminum -like .
Remember to use torque wrench.
Salim
Old 12-15-07, 11:36 AM
carguy07
carguy07's Avatar
Good tip about cracking the fill first. That would be me to drain and then figure out that I can not get the fill opened up.
So to confirm, I need 6 total if I am doing all three.
LX460
07-18-18 07:40 AM
Organized Garage Status
GX - 1st Gen (2004-2009)
04-11-18 09:13 AM
JAB
06-24-14 01:23 PM
mgtype
07-25-09 09:03 PM
carguy07
12-16-07 03:45 PM
Quick Reply: Crush washers for diff/transfer etc.
