50k Oil Change
50k Oil Change
It is time for the 50k oil change on our 02 RX300. I am considering the switch to synthetic, do you guys reccomend mobil 1? If not, what do you reccomend? How often do I have to change the oil with the synthetic? The oil filter? (Sorry, I am new to this stuff) Thanks in advance
Super Moderator
Mobil 1 or Amsoil are the two top choices. 5W-30 grade as your car is not quite ready for 5W-40 or 5W-50.
For your oil filter, I highly recommend the K&N oil filter (model number HP-1002), but your Lexus/Toyota filter will do you just about as good.
Oil filter should be changed every time you change the oil. With synthetic under normal driving conditions, I have heard 5,000 miles on synthetic, though I have switched to a 3,000 mile schedule.
I used Mobil 1 5w20 for better startup protection (lower viscosity for better lubrication) and Purolator pure one because of its synthetic fiber filter 10-20 micro particles. I am on 10K change interval based on an oil test study that Mobil 1 lasts 12K with a change of filter around 5K. Change interval is based on your usage and condition. Lexmex races on track in Mexico, I am sure how he uses his RX is very different than other owners.
lilbluu
06-01-10 03:44 AM
rivera156
Maintenance
12-31-03 01:23 PM
