115 Vac
My RX300 doesn't have a 120V outlet, so I use a 200W power converter.
I hook up a HEPA room air filter since the cabin filter isn't HEPA rated. Also good for hooking up portable TV/DVD, laptop and digital camcorder battery, toaster, etc. during camping trip.
Too bad hair dryer and microwave oven won't work.
Open the back door (hatch). On the right hand side above the tire well is a plug. It might have a cover on it - so you might not see it right away.
Then on the dash - left hand side right below where the button to open the fuel door release is located, is a button to turn on the AC plug in the trunk.
Didn't you get a manual with your car?? If you didn't - get one!
Nah my 2004 doesn't have this. Just dummy plates in those 2 locations. It must be an option that comes with something else. I have just about every option except the tow hitch, dvd entertainment system, and laser cruise control, so im surprised its not there.
Mike
Mike
Out of Warranty
115 Vac
The 115 v converter is a part of the RSES package, seemingly designed to power a game system, since it also includes A/V inputs. I assume that on-off switch is the "parental control". If you need 115 v service, try an aftermarket inverter or wire one in yourself. You'll find lots of uses for it - other than games . . .
gtstcactus
02-02-14 10:51 AM
