12 volt battery - doh moment
Need to verify something I just noticed after two years....
In the energy display in the navigation screen, is that the 12 volt battery sitting atop of the traction battery display?
Four grey bars with plus and minus signs on each side?
I was asking for a 12 volt battery charge display last week and there it is....doh!
must be the new glasses....
I dont think so...even if it was, it doesnt show you the actual charge
I think the energy monitor is pretty accurate in terms of location and pictorial reference. Obviously the 12V is not right next to the traction battery and is actually in the trunk (right?) so I would think the grey bars you see are just part of the outer shell of the traction battery.
Either way, it is useless if that is the 12V seeing as how it doesnt show the charage state
Ok, you got me curious. I hadn't noticed it before so I even went to the car and checked it. It's so innocuous I didn't even see it till I stared at it. So had to get out the book, all three of them , and tho the images such as the one RXSF posted did show it, none explained it.
Agreeing with RXSF as well that it's probably just the top traction battery shell it's probably useless as it really doesn't indicate anything. But ..... If anyone else out there in (h) land ever see's that grey box losing bars then post here as it's probably an indicator the 12v is dying. At least those are affordable.
Getting my 30k done in about a month and I plan on asking them to check it's condition as I hear it's a pain when it dies. I'm also to believe if it's replaced before it becomes terminal, connections of power can be kept through the process (from another battery) so no data is lost in the computers. If anyone has personal experience on this process, shoot a post here. But please don't speculate.
Well the 12V doesnt even stay constant so that bar should be fluctuating. When you first start the engine, it should be closer to 10V and then as the alternator starts charging it, it should avg 12.7 or something
Jim,
Won't speculate, but I drained the 12 volt in the first or second week of ownership. By then I didn't have much to lose, nor would have known what I lost. Yes, 12 volt dying is ugly. I know I wouldn't want it to happen in the dead of winter. Getting to the battery in back is out for me, always stuff back there plus a WeatherTech and getting to the terminals up front involves removing a plastic cover and those easy to lose button snaps. Not bad, but wearing gloves would make it be a pain.
Jim,
diamondmit
04-02-09 02:17 PM
