4 inch long bolt puntured tire
Old 02-26-11, 10:24 AM
ziggyziggy
ziggyziggy's Avatar
Default 4 inch long bolt puntured tire
Was driving yesterday and saw the tire pressure monitor issue a warning. The rear passenger side tire had 24 psi. I came out and saw a bolt head again the tread. I drove it to nearby tire store and they pulled it out. It was 4 inches long and about 1/3 inch diameter. The guy plugged it in 5 minutes and charged me $20. Now the tire was fine when i drove it on the highway home afterwards. I am just hoping it will last cuz the bridgestone 19inchers are expensive.
Old 02-26-11, 10:29 AM
kitlz
No, I don't play soccer!
Forum Moderator
kitlz's Avatar
ziggy, glad you didn't have a blow out on the highway. Now that would have been expensive. The melting snow around here has revealed lots of little surprises. Be careful out there.
Old 02-26-11, 10:48 AM
ziggyziggy
ziggyziggy's Avatar
Does anyone know if plugging the tire is sufficient or will it leak soon?
Old 02-26-11, 11:46 AM
kitlz
Forum Moderator
kitlz's Avatar
I had a nail similar to what you had taken out of one of the Goodyear tires on the 330. Took it to Goodyear and had it plugged. Held up fine for a year until I replaced the tires. You should be fine.
Old 02-26-11, 12:19 PM
larrs
larrs's Avatar
Tires are best patched from the inside. Ideally you want them to remove the tire from the wheel and apply a plug and patch from the inside, then remount the tire and re-balance the wheel.
Here is a technical article from Tire Rack:
http://www.tirerack.com/tires/tirete...jsp?techid=77&
Old 02-26-11, 06:20 PM
JimH2
JimH2's Avatar
https://www.clublexus.com/forums/rx-...a-s-tires.html
Believe there are better tires (at a lower price) than the Bridgestones to consider for your next set of tires.
Old 02-26-11, 06:57 PM
MEP7557
MEP7557's Avatar
Larrs is right. The best way is to plug and patch. That is what my dealership did when I took mine in for a screw. The Dealership told me it is the best way to fix a tire. No problems. They fixed it for free.
Old 02-26-11, 08:54 PM
ziggyziggy
ziggyziggy's Avatar
Is your dealet super nice or are they supposed to fix things like this for free?
Old 02-27-11, 03:43 AM
jskennedy
jskennedy's Avatar
been plugging my tires since i was 25yrs, i tend to be a magnet for flats
only has 1 plug fail & that was when the hole was too large for the plug
i do agree w/ others that an internal patch/plug is a better solution
the fact you got a 4" bolt in your tire is impressive, you didn't recently **** someone off did you
Old 02-27-11, 06:17 AM
MEP7557
MEP7557's Avatar
I'm not sure if all Lexus Dealerships fix flats for free or not. This is my first Lexus and so far I am very impressed with the service my Dealership has provided. I was very happy when they told me no charge.
Old 02-28-11, 03:22 PM
ziggyziggy
ziggyziggy's Avatar
After measuring, its actually a quarter inch diameter. Its been three days and tire is still good. Should i still be concerned?
Old 03-04-11, 01:09 PM
pslexus
pslexus's Avatar
My local Lexus Dealership in Nor Cal Bay Area quoted $39.99 to patch/plug a tire on my 2010 RX.
I8ABMR
09-03-13 07:45 AM
iGS430
12-24-10 08:50 AM
dk0515
Wheels, Tires & Brakes Forum
10-02-09 09:54 AM
stech
10-03-07 08:18 AM
fireballs gs400
03-06-05 05:15 PM
Quick Reply: 4 inch long bolt puntured tire
