P0430 Code
P0430 Code
We have an RX330 2004. On Monday morning with no symptoms the check engine light and VCS light came on. Yesterday I had the code read and the P0430 code was the culprit. I typically use regular gas but there has a been a gas shortage in TN so I had purchased the highest grade the weekend before. I had just filled up the second time before the light came one. The guy at auto zone recommended a catalytic system cleaner along with a fill up with the highest grade gas. I did that along with an oil change and had the code cleared. I drove 220 miles and the lights are back on. Again the car isn't showing any signs of something wrong. (I did have one time while at a long stop light that the idel felt jerky but nothing was happening with the idel and I couldn't tell if I was imagining it or not.)
thanks
thanks
thanks
thanks
I would pull the spark plugs and check them. I would also jiggle each coilpack (the ones that are easy to get to), while at idle in park, and see if you get a misfire. if you do you need to replace that coilpack. It could be a faulty sensor as well.
http://www.autocodes.com/p0430_2004_...ighlander.html
calvin2376
12-19-14 01:18 AM
