Help - Strange New Noise From Our 2007 RX-350
Old 09-01-15, 10:54 AM
sderman
sderman's Avatar
Default Help - Strange New Noise From Our 2007 RX-350
Our 07 RX350 has 47,000 miles and I just starting to hear (I think from the front) a faint rattling noise while driving. It's hard to describe but it sort of sounds like what you might expect if an empty plastic bottle was slowly bumping around in a plastic box. It is not a metal on metal type of noise. The shocks/struts appears to pass the old bounce test and the car does not seem to display any of the handling issues you get when you have worn shocks/struts as described at the KGB and other shocks/struts web sites and YouTube videos. I also checked the upper engine compartment to see if any plastic shrouds or covers were loose - they weren't.
Any and all thoughts on this would be appreciated!!! Thanks in advance
Old 09-01-15, 11:44 AM
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default .......................
I bet anything its the brake line plastic cover.
Slide under the drivers side near the mid section of the RX and check for a loose black plastic cover.
Its glued from factory and the weather eats it away and its now loose flapping away. Trim it back and done!
Thats what it looks like. I trimmed it back on ours fixed the noise.
Old 09-01-15, 01:44 PM
sderman
sderman's Avatar
Thanks!!!!!! I'll get there this weekend. In your photo at the top left, is it the white "line" where you trimmed? And what did you use to trim it? (tin snips?)
Old 09-08-15, 08:02 AM
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default ...........................
Yes, trimmed that thing as far as I could so it wont touch and make the flappy noise ever again.
And yes, snips...
Old 09-08-15, 04:48 PM
sderman
sderman's Avatar
And yes, snips...
Yup - the cover came unglued at the front. Cut off about 1" and the sound is gone. Looked at area of attachment and didn't see any obvious adhesive left. They should have done a better job affixing it. Thanks again'!
CaltonB
RX - 1st Gen (1999-2003)
09-23-17 01:41 AM
1989Lexus
Suspension
08-14-15 08:42 PM
mizak82
35
05-17-15 01:45 PM
lexusride
04-30-14 09:34 PM
TRDHarrier
02-10-03 06:58 AM
Quick Reply: Help - Strange New Noise From Our 2007 RX-350
