AFS flashing with both horizontal/vertical movement at init
2007 es 350
my afs light is flashing have a code b2410 my lights are not swilving left to right code says left headlamp no communation to ecu what is the problem ?
Hello. Though you're in the wrong forum section (this is for the RX, not ES), I'd guess the headlight systems are pretty much the same. If it's reporting a communication issue, I'd start with the wiring harness that plugs into the headlight. First, make sure it's plugged in tight. If it is, take the plug off and check for any signs of corrosion/dirt. If any is found, clean with electrical cleaner, and maybe an old toothbrush. Check the seal around the plug. Spray a small amount of WD-40 on the connector and reconnect. Hope this helps.
05hummer (12-18-16)
I just picked up a 2006 RX330, really like it! Only thing that seems to be wrong with it is the "AFS Off" flashing light. I have tried the various "reset" procedures, but have not yet checked underneath the car. The height adjuster seems to be working for me, just not the "turning" one.
Where exactly is the "turn" one located on the front axle, is it on the left or right? Is it under a cover of some kind? Just wondering, I will jack it up this weekend to take a look.
afs light
my left light was not swilving left to right , take headlight out under the light there is a motor inside expencive from dealer found one on ebay used 35,00 replaced it works great afs light out
Just checking in on my post from the end of November - can anyone tell me where the front AFS sensor is located on a 2006 RX? I found the rear one without too much hassle (and it looks fine), just wondering where the front one is.
Toyota OE part from UAE $45.00 US delivered part # 48906-35010. sold on ebay by MIDLAND AUTO SPARE PARTS TR. LLC 2 day delivery by Fedex.
This is the same link, sold on a 4 Runner sub assy.
GamblerZ
Performance & Maintenance
05-18-12 07:45 AM
