RX 330 and windows
Old 05-08-14, 12:46 PM
zogger13
zogger13's Avatar
Default RX 330 and windows
Hello,
I didn't start my car for the winter and the battery died. I recharged it , but after that none of the windows work except for the drivers one. also the windows don't work from the drivers controls too, and the sunroof isn't working as well.
Please help, maybe I can do something about it before visiting the auto tech.
Thanks
Old 05-08-14, 01:01 PM
Band
Band's Avatar
Search: "reset windows"
Old 05-08-14, 01:31 PM
mpatton
mpatton's Avatar
Originally Posted by zogger13
Hello,
Thanks
You need to reset them from each door switch. Start with your drivers door, down, hold 5-6 seconds, up, hold 5-6 seconds. then go to the passenger door, then rear passenger door, then rear driver's door and then the sun roof. The sunroof is a little different, so look in your manual, I can't remember it off the top of my head.
or..search on this forum, this has been answered a lot. because I may be inaccurate in the order to reset them.
Old 05-08-14, 01:32 PM
zogger13
zogger13's Avatar
Thanks! just did this and the back windows are working fine from the drivers control and on their own too.
But the on the passenger's window the light on the button isn't even blinking , it's just off, and not working from the drivers control too, and the sunroof still isn't working.
Old 05-08-14, 05:13 PM
Rainbird
Rainbird's Avatar
Prevention - Next winter put a trickle charger on the battery. It will start right up in the Spring.
Old 05-09-14, 04:58 AM
zogger13
zogger13's Avatar
I will do that next winter for sure.
But still what do you think the problem is with the front passengers window and the sunroof? Still no signs of life.
The light on the passengers window button isn't even blinking , it's just off.
Old 05-09-14, 08:50 AM
RX330inFL
RX330inFL's Avatar
Once you have a proper charge on the battery I would disconnect it for half an hour. Then, connect it back up and reset. Perhaps all it needs is a proper reset.
Brandoz
01-28-19 04:42 PM
jimbo409
05-22-13 09:35 AM
thomastan
01-29-09 08:33 PM
kreed74105
RX - 1st Gen (1999-2003)
04-29-08 09:03 AM
markesc
SC- 1st Gen (1992-2000)
11-20-04 07:23 PM
Quick Reply: RX 330 and windows
