Power Outlet Cover
[QUOTE=rudyasp;7953670]Since my car is non smoking area - i not only changed the look, but also the function - the lighter was removed and substituted with the female USB port for my Vaistech MML:
Yes, I did the same. It works very well for my purposes.
No, it is actually a USB cable which plugs into the back of his VAIS hardware. Just discard the bracket which comes with it.
http://www.ebay.com/itm/360519075754...84.m1438.l2649
They are often on sale for $3.99 or less with free shipping.
Here is a more expensive (double usb) one at Amazon
.. others:
http://www.meritline.com/iphone-ipad...--p-76772.aspx
http://www.meritline.com/usb-griffin...--p-72452.aspx
http://www.meritline.com/iphone-usb-...--p-38528.aspx
(don't forget to check the Amps - the iPhone will charge on low amps, the iPad2+ needs more)
http://www.newegg.com/Product/Produc...82E16882021207
-- but you get the idea.
Good luck!
i had such a small charger fitted into my previous car, but my current setup not only charges my ipad2 (and iphone4), but plays the music on it, displays the info on the screen, scrolls using the steering wheel buttons. This together with the dvd inmotion hack removed everything i wasn't happy with on my ride.
Well ... Missing range display and high beam drl's is what i still miss.
@ RX330inFL - the cable is exactly the same! Thank you!
Although I was thinking to do the same (drill and add USB socket) i decided to remove the lighter and replace with the female USB. Now i don't have the cigarette lighter, but the mod is totally reversible.
You are refering to the post of 1koolfella. I just found out this thread.
