Mark Levinson CD changer - Shipment Mode Setting
Old 01-24-13, 09:13 AM
Twedwards3
Twedwards3's Avatar
Default Mark Levinson CD changer - Shipment Mode Setting
I have a 2006 RX 400H, the Mark Levinson CD changer displayed an error 4. I purchased a replacement factory unit from an Ebay seller. Unit appears to be fine, installed it. Before shipping they put it in "SHIPMENT MODE" and I can't figure out how to undo this mode. Anyone with answers?
Thomas
Old 01-24-13, 09:58 AM
RX330inFL
RX330inFL's Avatar
Thomas
Welcome to Club Lexus, Twedwards3.
Am going to assume you installed this with the battery still attached to your vehicle. Believe the negative terminal needs to be disconnected on your RX before you hook up the connections to your new unit. You will need to disconnect everything, remove the negative terminal from your battery, reconnect the stereo, then connect the battery back up.
Shipment Mode is used for transport to park moving parts such as the CD player laser diode.
You might try confirming this with the seller on eBay.
ehrgeiz
05-11-16 10:52 AM
MuGGzyx
SC- 1st Gen (1992-2000)
04-22-09 09:25 AM
NJ240sxMan
06-22-07 12:44 AM
MikeM
08-13-02 10:48 AM
Quick Reply: Mark Levinson CD changer - Shipment Mode Setting
