bluetooth won't hang up after call
Old 12-28-11, 02:29 PM
msgntsu
msgntsu's Avatar
Default bluetooth won't hang up after call
I searched thru all the bluetooth listings, but couldn't find an issue like mine. I have a 2007 RX 350. I just recently started using bluetooth. It was working well and then all of a sudden I have an issue after a call. I hang up my phone, but the screen still shows that it is talking; although, no call is being made. I have to stop and start car to get it to clear, so I can start again. However, it will only work once and then it still won't hang up. Any ideas?
Old 12-28-11, 02:42 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
have you tried the hang up button on the steering wheel?
Old 12-29-11, 06:28 AM
msgntsu
msgntsu's Avatar
No. I wasn't aware that there was one on the steering wheel. I will check that out and see if it works.
Old 12-29-11, 07:19 AM
RX330inFL
RX330inFL's Avatar
Can you post a picture of this button for the OP? I only have an RX330, so cannot do that. Thanks.
Old 12-29-11, 08:32 AM
Rainbird
Rainbird's Avatar
The RX350 has "answer and hang up" buttons on the right cross member of the steering wheel. A very convenient feature. I wasn't aware these buttons were missing on the RX330.
Old 12-29-11, 08:33 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
Bluetooth wasn't available on the '04 330. It was introduced on the '05 330.
Old 12-29-11, 11:30 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
sorry: wifey took the car to work....but this is what I found from google....hehe
"answer/hangup" is the first switch on the right hand side...give that a try and keep us posted. Good luck
Old 01-01-12, 06:21 AM
msgntsu
msgntsu's Avatar
Thanks for all the replies. I did try using the hang up button on the steering wheel, but received the same result. It still doesn't hang up. Anyone have any other ideas?
Old 01-01-12, 07:44 AM
Carver
Carver's Avatar
You might try resetting the computer before you start throwing money at it. Disconnect the positive terminal for at least 20 minutes. Be aware you will lose most if not all of your presets.
Old 03-10-15, 03:43 PM
geneglv
geneglv's Avatar
I have the same issue with my CT200.
What phone do yu have?
Old 03-10-15, 03:58 PM
Rainbird
Rainbird's Avatar
You may not get an answer to your question. The OP has only eight posts and the last one was over three years ago.
Old 04-01-15, 08:24 AM
msgntsu
msgntsu's Avatar
Mine was a BB at the time. I corrected the by removing the battery cable and resetting. I now have a smart phone and the issue hasn't happened since.
Old 04-01-15, 09:17 PM
Carver
Carver's Avatar
You're welcome!
rstanleyb
LS - 5th Gen (2018-present)
12-04-18 02:30 PM
Mybearlady
RX - 3rd Gen (2010-2015)
06-12-18 03:43 PM
vinniec
RX - 4th Gen (2016-2022)
01-20-18 04:39 AM
johnnylt
08-18-15 09:37 AM
johnnylt
07-16-15 06:43 AM
Quick Reply: bluetooth won't hang up after call
