Advice needed
Advice needed
Hello,
My Lexus is idling roughly at start-up as well at stop lights. I put a scanner on my vehicle and two error codes appeared:
P0137
P0304
I re-set the codes and the check engine light has not re-appeared but the rough idle is still present.
Any help would be greatly appreciated,
Chris
P0137
P0304
Chris
Registered User
OBD Codes
A .5 second search on Google found this information.
http://engine-codes.com/search_codes...ar=P0304+LEXUS
http://engine-codes.com/p0137_lexus.html
Hello,
P0137
P0304
Chris
P0137
P0304
Chris
Believe those to be O2 sensor and engine/cylinder misfire. Believe others can chime in with more complete information as to causes. If the problem just suddenly appeared, rough engine, then it could just be one tank of gas that needs treatment. If the problem has been gradually appearing over time you may need to consider cleaning the MAF as well as looking at the condition of those sensors.
Registered User
Help On Club Lexus
I guess it was a bit sarcastic. But if your looking for advice on the Internet. And have a specific question. It would probably be a good idea to ask one.
Maybe something like this.
So yesterday morning my 2007 RX350 FWD with 41K miles. Doesn't start the first time I try. Works the second time. So ok.
On the way to work it seems like it doesn't have enough power. You have to step on the gas a little more.
I get home after work and cleaning Mass Air Flow Sensor. And I go ahead and change out the engine air filter.
Today I drive around town. And you can tell its not idling right. At the red light you can see the Tach drop for a second from 800 to 600.
Its not throwing any caution lights.
And ideas before I take it back to the dealer?
https://www.clublexus.com/forums/rx-...les-rough.html
You would have found this thread by doing a .5 second search on Clublexus
Update.
I took my vehicle to the dealer. The misfire fault code was still stored but the p0137 vanished. After a diagnosis and lengthy drive the misfire did not happen again. The ignition coils were switched from cylinder 4 to cylinder 2. Another test drive and no misfire. So we will see what happens and I will provide updates.
Has anyone run the Toyota fuel treatment through their system? Any feedback would be appreciated. I always run premium fuel and 90 percent of the time I use shell v-power
Super Moderator
Update.
Sometimes the misfires happen because of an issue with the gas, the air coming in, something with the voltage (even if the battery is fine). Sometimes the issue is temporary or it can be permanent and that vehicle will bog down. At least with my RX300, when that happens, the check engine light will flash.
Fuel injector cleaner can only help so much, that's usually used on other situations. My personal favorite though is the Redline Fuel System Cleaner (Pep Boys is where I see it at down here in terms of being sold in a store).
Super Moderator
I don't blame anyone in this thread or anyone else for getting upset. These things can be extremely frustrating even for me and with an older vehicle, no matter how much I take care of it, I come to expect something will go amiss. The dealers do have all the tools at their disposal and will see these vehicles in and out every day. However, sometimes, things need to be road tested and it can be difficult to make something pop up. A freeze frame on an OBD2 or even a Toyota/Lexus diagnostic scanner can only tell you so much.
Sometime a little corrosion on the coil contact to the plug could be a culprit...I would have looked at the contact and made sure it is corrosion free and long enought to make firm contact with the plug...
Update part II
After sitting in the cold for a few hours at the dealership, when I started my vehicle up the same symptoms appeared. I quickly summoned a technician. The problem was now a misfire on cylinder 2 which was the 'new' location of the ignition coil from cylinder 4. The ignition coil is the problem.
New ignition coil orders, as nothing is ever stocked anymore, everything should be back to normal on Monday
Thanks for everyone's help
Chris
Chris
Update part II
Chris
Chris
DaveN
03-08-14 03:50 AM
