Oil drain plug
Old 01-30-11, 10:09 AM
bozilla
bozilla's Avatar
Default Oil drain plug
I have a 09 RX350 and found that the oil drain plug had no gasket or crush washer.
This vehicle has always been serviced at the at the dealership.
Does this vehicle have a crush washer for the oil pan drain plug?
The vehicle has never leaked oil
Old 01-30-11, 11:35 AM
Adamjeeps
Adamjeeps's Avatar
Yes, there is a washer that goes on the drain plug. It is included with the oil filter kit from the dealer. You are supposed to replace it every time you change the oil, as it crushes when torqued down. You should tell the dealer their oil change man is not following procedures.
Old 01-30-11, 11:38 AM
Rainbird
Rainbird's Avatar
Here is a DIY oil change procedure with PICTURES. The GS350 and RX350 are done the same way. The old spin off type oil filter went away with the 2007 model year.
https://www.clublexus.com/forums/gs-...-pictures.html
Old 01-30-11, 11:49 AM
bozilla
bozilla's Avatar
Default Oil Drain Plug
Thanks for the info. I had and 02 RX300 and it had a crush washer on the oil drain plug.
I just wanted to make sure because this engine and oil filter system is different.
I wonder why there was no leak at the drain plug.
Old 01-30-11, 01:46 PM
arnieosp
arnieosp's Avatar
Are you sure the gasket did not get stuck to the oil pen? Mine does all the time, I have to pry it off with a flat screwdriver.
Old 01-30-11, 04:28 PM
Rainbird
Rainbird's Avatar
Originally Posted by arnieosp
Are you sure the gasket did not get stuck to the oil pan? Mine does all the time, I have to pry it off with a flat screwdriver.
I bet you are right! If you notice in the pictures of the GS350 oil change above, the drain plug gasket was stuck on the oil pan as well.
Old 01-30-11, 07:27 PM
khilgers
khilgers's Avatar
when I did the oil change on my '04 a couple weeks ago I had to actually pry the old gasket off.
Old 01-31-11, 11:54 AM
bozilla
bozilla's Avatar
Default oil drain plug
There was no crush washer on the drain plug.
When I first started to remove the drain plug I noted no washer so I tightened the plug back up, and made this post.
I went to auto parts store and obtained the washer and did the service today.
Old 01-31-11, 12:04 PM
willyb0b
willyb0b's Avatar
I recommend installing a Fumoto drain valve - http://www.fumotousa.com/ . Very secure and easy to use. Worth the $20-25 bucks and makes draining oil so easy. I have one on my 09 RX350 and have had one on all vehicles i have owned.
Uda880
1Gen RC350 / RC-F Classifieds
01-05-18 11:01 AM
GRPFAN
RX - 3rd Gen (2010-2015)
03-26-12 09:14 AM
nachat
11-14-04 10:19 PM
JustinK101
IS - 1st Gen (2001-2005)
22
05-09-04 03:06 PM
toy4two
RX - 1st Gen (1999-2003)
20
11-26-03 03:20 PM
Quick Reply: Oil drain plug
